Author Topic: TV receiver wont turn back on with remote control  (Read 1013 times)
Offline drummerdimitriTopic starter
  • Country: lb
« on: December 07, 2018, 06:28:08 pm »
We've switched to a new "TV provider" and they installed a new TV receiver.
The remote control to switch the receiver on and off works only to turn it on but since it's hidden away for aesthetic reasons, a small sensor is placed below the TV which can turn off the receiver but wont turn it back on.
My question is how can I find a way to turn the receiver back on with the remote control without having to place it in the line of site of the remote control?
Thanks!
Offline cdev
Re: TV receiver wont turn back on with remote control
« Reply #1 on: December 07, 2018, 07:44:03 pm »
"TV provider" ? Literally?
(Sounds like the sensor is powered from the TV so...)
Did you ever get your noise issue sorted out?
« Last Edit: December 07, 2018, 07:46:25 pm by cdev »
Offline Bud
« Reply #2 on: December 07, 2018, 08:57:15 pm »
You can point the receiver behind the TV to the wall to the right or left from the TV or to the ceiling but may be hard to find a right angle and the remote also will have to be pointed to the same surface at an angle which may be awkward and work only from a certain position of the person in the room, anywa you can try, in a small room may be enough reflection from the walls to trigger the receiver.
  • Country: lb
« Reply #3 on: December 08, 2018, 12:03:16 am »
Problem is the receive is tucked away behind a plywood wall so there's no way that would work.
My previous receiver had a similar sensor placed below the TV and I could turn it off and back on with the remote control no problem not sure why this new service provider's receiver works differently.
Can I hack it somehow? Also, for some reason the sensor has a bright red led thing going on and is powered by a usb port which can be very distracting in low light conditions. Maybe a new sensor is in order  :-//
  • Country: lb
« Reply #4 on: December 08, 2018, 12:04:36 am »
I meant to say service provider.
You mean the noisy upstairs neighbours? No but the noise levels have been reduced to an almost tolerable level. Still looking for a place of my own  :palm:
