Author Topic: TV to Oscilloscope conversion.  (Read 9347 times)
Offline FerrotoTopic starter
« on: July 30, 2012, 06:31:34 pm »
I saw a project awhile back where a TV was converted into an oscilloscope. Basicly on the back of a CRT there are two coils one that controlls the x deflection of electrons and the other that controls the y deflection. According to the tutorial all you do is connect the x defliction coil to a sawtooth generator and the y defliciont coil to your test signel.
Recently I was at a yard sale and found an old portable black and white TV for 5 bucks and figured I'd give it a try.
This is the tutorial I'm following. It tells me to connect the horizontal deflection coil to the location on the board where the vertical coil used to be but I want to be able to adjust the timebase which means some type of variable sawtooth generator I'm thinking a 555 timer. I still don't know how I'm going to do the triggering circuit.
I was wondering has anyone here taken on this type of project before.
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: TV to Oscilloscope conversion.
« Reply #1 on: July 30, 2012, 07:11:41 pm »
In the 1970s, a TV to scope converter was my very first scope, but what I built included an RF  modulator so the TV needn't be opened and hacked for safety reasons.  You could also use any TV tuned to channel 3 or 4.  The downsides were many, but it was cheaper to build then than buy or have nothing at all.  Today, the quality will be far less than if you simply refurbished a used Tek.   You could also do this with an old CRT monitor on the same principle.
http://markbowers.org/home/crt-oscilloscope
Best Wishes,
 Saturation
Offline IanB
« Reply #2 on: July 30, 2012, 07:36:17 pm »
The major issue with X-Y deflection coils is that real oscilloscopes use X-Y deflection plates (electrostatic instead of electromagnetic). I think the use of magnetic coils will produce major bandwidth and signal distortion problems.
These days you could do much better by using a USB scope or a computer sound card and plotting the results on the computer display. For sure you would be limited to low frequencies, but I guess a converted television would have much the same limits.
Offline EEVblog
« Reply #3 on: August 01, 2012, 11:49:02 am »
It's a very 70's type project to build.
Few would build one these days for anything useful, but I have seen a few recent builds around. Sorry, no links to hand.
Dave.
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #4 on: August 01, 2012, 12:57:38 pm »
The 'modern' way of doing it would be to create a frame store out of memory. This is then addressed with horizontal and vertical address counters which correspond to the H and V timing required to make a valid TV signal. The input side would write into memory to produce the desired display waveform.
The above is a slightly simplified explanation of what would be needed!
Offline RCMR
« Reply #5 on: August 01, 2012, 09:56:37 pm »
Wow... brings back memories.
Back in the 1970s I made a lot of beer-money by converting old B&W TV sets into oscilloscope-like displays that were very popular at discos.
You'd simply hook the Y-axis of the yoke up to the output of the audio section (ie: instead of the speaker) and feed the music into the top of the volume pot.
The X-axis of the yoke would be hooked up to the output of the vertical output stage (thus giving a 20mS scan rate).
Some strips of coloured cellophane over the front of the mono CRT and you'd get a truly excellent multi-coloured oscilloscope-like display.
I'd buy the old TV sets for about $20 each and sell the "DiscoWave" units for about $50 each (remember 1970s dollars).   I used to earn about $50/hour doing this and couldn't keep up with the demand.
Works really well for audio frequencies.
The following users thanked this post: Metatronic_Mods
