I found this circuit in a four year old thread here. It is a Multiple FeedBack (MFB) topology if I'm not mistaken. It looks like exactly what I want. I've never seen this filter in a differential input arrangement. I will need to dig a bit to find info on how to set all the values.
The bit that concerns me, is the fact that in my design, I need to use it both as a differential input circuit, and as a single ended input, in different operating modes. When a single ended input is applied, I don't have a way to ground the unused input. I expect the signal will need to be applied to the inverting input, but that still leaves the non-inverting input flopping around. Maybe it's better to say the non-inverting input would be dragged around by C9, the 470 pF cap.
This design is very tight for space, very tight, so no room for extra logic or amps! Anyone know if this circuit will still function effectively if C9 is replaced by a pair of 1 uF caps to ground? Or does that impact the differential aspect of the filter?
The input operates in several modes, including 50 ohm terminated, single ended; 600 ohm, differential; and "high" impedance, differential. "High" impedance doesn't currently have a spec number on it. I expect 5k would be adequate, preferably 10k. If each input leg had a 4.7k resistor to ground, that should serve as a ground for the non-inverting input when in single ended mode, in place of splitting the C9 cap, no?
(ignore the op amp part number, I'll be using something else)
[attachimg=1 width=1200]
