Author Topic: UART Communication between GSM and GPS  (Read 618 times)
Offline AankurTopic starter
  • Country: in
« on: April 24, 2019, 10:44:27 am »
I want to establish a UART Communication between GSM and GPS.
The Supply Voltage of GPS is 3.3V.
The Supply Voltage of GSM is 3.8V.
The measured RX/TX Voltage Levels of GPS is 2.8V and 0V (for logic High and logic Low).
The measured RX/TX Voltage Levels of GSM is 1.8V and 0V (for logic High and logic Low).
Since there is a difference between RX/TX logic levels of the GSM and GPS, So I am
not able to establish the UART Communication between GSM and GPS.
I am using the interpreter of the telit GSM module to process the data of the GPS.
I am not using any micro-controller to in between the GSM and GPS.
Please suggest me a possible way to perform voltage (or Logic) level shifting.
Offline tox3
  • Country: lv
Re: UART Communication between GSM and GPS
« Reply #1 on: April 28, 2019, 10:10:17 am »
GSM modules usually has output with 1.8V (for example VAUX/PWRMON on Telit LE910), ypu could use it to power level shifter ic.
Not sure about GPS module though. Specific part number would be helpful
Offline mikerj
« Reply #2 on: April 28, 2019, 01:27:57 pm »
Have a look at this TI app note.
