My patience for soldering multiple power resistors to create a high power ac load has run out, I always need one more resistor than required. So I’m going to build a binary weighted load. I welcome comments from anyone that has built one because as I’m considering myriad design trade offs, some compromise is going to be required.
Ideal specifications:
1) Voltage: prefer 0-250Vrms
2) Current: 0-20A
3) Closed loop
4) 12 bits
5) Power 500W
6) Inexpensive ( stop laughing)
Thoughts..........
100W eBay power resistors are dirt cheap @ about $1-2 a piece.
Switches:
Initial thought was no or minimal # of relays, however triacs are going to be less than ideal with low input voltages, for example an audio amplifier or ac current source.
MOSFET SSR’s are inexpensive for low currents (100ma@400Vp), above that relays are cheap, I’m just cringing at the thought of all that relay chatter when the current is adjusted. Realistically will rarely use at 240V, so hopefully 400V SSR is adequate.
I will use an Arm with 12 bit A/D to measure V, I and calculate power dissipated to limit current when V is high.
Cooling will use a couple of heat sinks fins to fins to create a tunnel with fan forcing air through the tunnel and out the case.
Comments welcome.
Sent from my iPad
