I created this build using the LT3081 as the foundation. The LT3082LT3092 providing a small current source to offset the set pin, allowing use of a 10K pot that I already have in my bin. Much of the design takes points from the DC2132 demo board and from datasheet examples. Been working on it for over a month now. So I hope that my efforts are not completely incompetent as this is my very first wack at building anything more than a educational/example circuit.
My goal was a 24V 3A supply with as small a footprint as possible. The SMD component footprints are all generic 0805, I can resize/nudge things around to accoomodate bigger/smaller sizes.
The spice model seems to test out just fine and it is attached below. I just modified the one provided for the DC2132. If there are any gross errors or major problems with my design or layout, please let me know.
