I wanted to have an "Ultra Low Noise Lab Power Supply" for experiments with voltage references and instead of having a bunch of batteries (remember your green finger print on this earth) and instead of always using a low noise regulator for each quick and dirty voltage reference setup I decided to build a power supply for this and similar purpose.
LT3042 and LT3045 are available for a while and page 23 of the datasheet gave me exactly what I needed. It took its time to grow this idea and meanwhile some guy on
DIY audio came across with a ready to go pcb for a first setup.
The price of 12€ for an audiophile white looking board seemed okay to modify it to my needs. It's a two channel, fixed current board paralleling 3x LT3045 giving up to 15V and up to 1.5A per channel, more than enough. Instead of the 10way trimmpots on this board I added Bourns multiway pots in 100k and 100k with 100k in parallel for the voltage setting of up to 15V.
Further I bought an
50VA, 12Vac toroidal transformer and some panel meters for
voltage and
current. The panel meters are supplied by the rectified voltage at the input of the voltage regulators.
The case was planed using Schaeffer front panel designer, exported as dxf and lasered at a local company. I decided to use a proMa EG2 aluminium profile (103mmx56mmx168mm) based chassis, but with wider front and back panel instead of standard 103mm and thus wider top and bottom plate.
It works pretty well, even though I seem to have some minor issues with mains hum coupling somewhere into the output. I'm currently investigating on that and ordered some self-adhesiv mu-metal foil to wrap it around the transformer. Further I will replace cables by shielded ones.
One the other hand without the transformer it is a pretty nice extender for existing lab power supplies, forming them into a low noise supply for the bench. So this is the idea. Let me ask, is there any interest in a group buy of bare boards and the aluminium chassis parts? All other parts can be easily bought in the bay and at your local electronic store or distributor. I plan to redesign the board with additional current limit setting, which is currently missing.
Meanwhile the guy with the pcb cracked up and sells assembled boards with fixed output current to the
audiophile community for big bucks.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/xfacepalm.gif.pagespeed.ic.EBDwh1hCfo.png)
EDIT: Added a first picture of my build.
-branadic-
