Author Topic: Ultra low noise voltage reference  (Read 15820 times)
Offline altaicTopic starter
« on: March 09, 2016, 12:04:24 am »
Apologies if this has been discussed before-- I searched and didn't come up anything that answers my specific question, which is: What is the lowest noise voltage reference practically/cheaply available? I'm looking to characterize the noise on a 24-bit ADC that I'm working on.
As I understand it, even batteries have different characteristics due to their chemistries which can introduce or pick up noise. I recall someone mentioning mercury batteries awhile ago, but I don't think noise was discussed. Am I overthinking it, or is there a preferred ultra low noise voltage reference out there that won't break the bank?
Offline uncle_bob
Re: Ultra low noise voltage reference
« Reply #1 on: March 09, 2016, 12:17:35 am »
Hi
Lowest noise and cheapest are pretty much directly at odds with each other. Is $2,000 "cheap" for what you are doing? (it's dirt cheap by some standards).  Is noise well below the 24 bit level required? Is there a stability requirement as well as a noise target? Is this a lab bench measurement or are we building a few thousand copies a week?
Depending on the twists and turns, there are a lot of ways this could go.
Some math:
24 bits is 0.06 ppm. If you are after a lab setup you typically would want around 0.01 ppm of error contribution from your source.
If your ADC has a 0 to 2V input, that would get you to a 0.02 uV error budget. At that level you would need to include thermocouple offsets and other "interesting" things along with noise and drift.
A fairly good reference IC is going to be in the 2 ppm / C range. With a 0.06 budget, you will need to control your drafts and temperature changes to well below 0.1C. That gets into things like oil baths. Is this ok in your application?
Lots of zigs and zags.
This is about as close as you will get with a "cheap chip":
http://www.linear.com/product/LTC6655
It's still a few orders of magnitude away from your requirements.
Bob
« Reply #2 on: March 09, 2016, 01:22:25 am »
Thanks for the response, Bob! This is a bench measurement so I can tweak my design. At this stage, I don't really care about drift and such, only noise in a DC measurement. Re. budget, $2000 would be pushing it currently; later on, assuming this project turns into a marketable product, that wouldn't be a problem.
The ADC in question, BTW, is the LTC2380-24 [http://www.linear.com/product/LTC2380-24]. Quite a nice beastie, which I hope to learn a lot about analog design with.
Offline uncle_bob
« Reply #3 on: March 09, 2016, 01:54:34 am »
Hi
That's only about a 22 bit part. The last two bits are noise. At a reasonable rate, the last 5 bits are noise (see page 6 in the data sheet).
Bob
Offline barry14
« Reply #4 on: March 09, 2016, 01:58:53 am »
Linear Technology recommends their reference device,  LTC6655-5, be used as the reference for this converter.  It has a 2 ppm/C drift and they recommend using a capacitor to lower its noise level. The noise of this reference represents the lowest level that you can achieve. You should look at the specifications for this device.  LT16 bits tests the converter by applying a portion of the reference voltage to the input and then performing FFT's on the output.  The specified SNR, using this method, is about 100 dB (equivalent to about 16 bits).
Offline uncle_bob
« Reply #5 on: March 09, 2016, 02:01:21 am »
Hi
If you need the link to this part, it's in my post back a few in this thread.
Bob
« Reply #6 on: March 09, 2016, 02:48:46 am »
Thanks guys. I do realize it's ENOB is below 24 bits, and indeed I'm planning on using the LTC6655 voltage reference and the LTC6363 opamp to drive the ADC. I'm also planning on using the averaging filter for increased ENOB, since I don't always require fast sampling.
Once it's fabricated, I would like to characterize the ADC's performance with an ultra-low noise DC source, and experiment with the design to see how noise performance is affected. So, I thought batteries would be a good place to start, since they're cheap and, I imagine, pretty low noise. I'm wondering if anyone has characterized various types of batteries for noise or if there is an appreciable difference between different chemistries.
Offline retrolefty
« Reply #7 on: March 09, 2016, 03:27:34 am »
 That is a very good idea/project. With so many volt-nuts around here I'm surprised it hasn't happened already.
Offline ChunkyPastaSauce
« Reply #8 on: March 09, 2016, 04:03:02 am »
http://tf.nist.gov/general/pdf/1133.pdf "Measurement of voltage noise in chemical batteries"
« Last Edit: March 09, 2016, 04:04:38 am by ChunkyPastaSauce »
« Reply #9 on: March 09, 2016, 04:26:59 am »
Yes, thank you! Surprising that Ni-Cd performed best.
Offline mojoe
« Reply #10 on: March 09, 2016, 07:20:51 am »
Very interesting paper. I wonder if NiMH would perform as well as NiCad. I don't know the internal resistance of NiMH.
Am I correct that the paper stated with NiCad, the noise did not increase while float charging?
Offline Fungus
« Reply #11 on: March 09, 2016, 09:43:07 am »
I'd have thought adding a decent capacitor across the output would do more to reduce noise than buying a more expensive reference.
Online Kleinstein
« Reply #12 on: March 09, 2016, 05:35:41 pm »
NiMH cells tend to have a higher internal resistance. Also the hydrite has lots of material internal stress and could thus cause noise. So I won't consider NiMH worth a try. Some cells are sensitive to mechanical stress from the outside, so there might be some very low frequency noise / signals.
If a LT6655 is not good enough, one could use the average of 2 or 4 of these to get lower noise. This also applies to other reference chips. So if temperature dirft is not critical, even a larger quantity of LM329 might be a way to go.
« Reply #13 on: March 09, 2016, 06:39:29 pm »
Also resistance isn't dependent only on chemistry - structure matters. As in the paper, simply selecting larger current capacity cells from the same chemistry significantly reduces noise due to lower cell resistance.
Temperature will also effect noise level, but not sure of the relationship... typically battery resistance increases with falling temperature, while many noise processes decrease with [falling] temp... not sure which wins.
« Last Edit: March 09, 2016, 06:57:56 pm by ChunkyPastaSauce »
Offline suicidaleggroll
« Reply #14 on: March 09, 2016, 06:49:43 pm »
Really high frequency noise, sure, but what about noise in the 1-100 Hz region?  A cap won't do anything for that, you'd need an RC combination, and to get the cutoff frequency that low you'd end up needing a series resistance so high it would make the output pretty much useless for driving an ADC reference line.
Offline Fungus
« Reply #15 on: March 09, 2016, 07:09:36 pm »
I think the voltage reference itself is supposed to deal with that (by adjusting its output).
« Reply #16 on: March 09, 2016, 07:35:17 pm »
It is, and the better the reference, the better the job that it will do.
Offline splin
« Reply #17 on: March 09, 2016, 08:37:25 pm »
Ni-cd batteries are almost certainly the way to go - relatively low cost and much lower noise than any solid state reference but you have to be careful of their temperature dependence when making low frequency measurements below 1 Hz. See reply #27 here:
https://www.eevblog.com/forum/projects/low-frequency-very-low-level-dc-biased-noise-measurements/25/
Offline splin
« Reply #18 on: March 09, 2016, 08:54:15 pm »
On reflection, the temperature sensitivity of the AA cells that I measured was very likely due to the change in thermal EMF at the negative given that the steel battery case is directly connected to the negative but not the positive terminal. Thus any change in the environment temperature will get reflected at the negative connection very quickly through the thermal conductivity of the battery sleeve, with the positive taking much longer to equalize. A well insulated box and lots of time to stabilize should be OK.
Offline uncle_bob
« Reply #19 on: March 09, 2016, 11:04:58 pm »
Hi
No available battery will be stable enough / quiet enough to do what you are trying to do.
If you have a 6655 putting 5V into the ADC, use another one as the "calibration" device. Run it at 2.5V or whatever you decide to check things at. The ADC does not care which input the noise comes in on. With identical sources, the "real" result will be 0.707 times whatever you read.
If you want to step the voltage off as you test, you are going to need a pretty good bridge. That gets you right back up into the > $1K range on the surplus market.
Bob
« Reply #20 on: March 09, 2016, 11:38:27 pm »
Fascinating thread; thanks for the pointer.
Hi
Bob
Ah, interesting. So using two 6655s to double the noise, and take the RMS (thus sqrt(2)/2)?
Offline uncle_bob
« Reply #21 on: March 10, 2016, 12:08:24 am »
Hi
Bob
Hi
If you get to the point that they add as power, yes you get the 0.707. If you believe they add as voltage then it is 1/2.
If you have a "noiseless" bridge, and run it off the *same* 6655 as runs the ADC, you would not get either correction. In that case, what you read is what you get.
Bob
Offline splin
« Reply #22 on: March 10, 2016, 10:04:08 pm »
Hi
How on earth did you come to that conclusion? The NIST noise measurements of an AA Ni-Cd @1Hz were more than 2 orders of magnitude quieter than an LT6655 when normalised to 1.2V. The Ni-Cd noise measurements at 1 Hz must include all the drift, stability, thermal EMF etc. contributions.
Below 1 Hz the 6655 exhibits rising, 1/f, noise but the NIST measurements stop at 1 Hz unfortunately.  I don't have much doubt that 10 second measurements for 0.1 to 10 Hz noise characterisation would be significantly worse than at 1 Hz - especially if larger C or D cells are used with their greater thermal mass and significantly lower noise.
Perhaps you have some evidence to the contrary?
Offline uncle_bob
« Reply #23 on: March 10, 2016, 11:23:11 pm »
Hi
Hi
Having done the same testing they did in a real world temperature environment ....
Bob
Offline alanambrose
« Reply #24 on: March 11, 2016, 05:10:40 pm »
I wonder if anyone has a sense of where LiPo's would fall on the NIST analysis? One theory seems to be that noise is a ~function of source resistance for batteries so LiPo should be up there?
A.
“A foolish consistency is the hobgoblin of little minds"
