Author Topic: ultrasonic cleaner dimensions/power  (Read 1544 times)
Offline tekguyTopic starter
« on: October 01, 2022, 03:48:58 pm »
Hi all,i am putting together au/c it has 5x 50watt transducers at 40kc,the tank is approx 14"x10" and a usable depth of about 4",is that a good power level for the size of the tank or will it damage things beeing cleaned,Cheers.
Offline Conrad Hoffman
    • The Messy Basement
Re: ultrasonic cleaner dimensions/power
« Reply #1 on: October 01, 2022, 05:04:08 pm »
That seems a lot different then what I'm used to, but I don't know about the higher frequency designs. For half that frequency the depth would be near 10" and maybe two transducers. There's quite a lot to designing these things to avoid standing waves and such. The standard test is how quickly it will perforate aluminum foil, so yes, you can damage small parts. The high frequency designs get into smaller area and are probably safer for small parts, but I'd want a power control.
« Reply #2 on: October 01, 2022, 05:48:57 pm »
it has 2 driver boards,1 is 2x 50watt and the second driver is 3x 60 watt,i plan on having a two way switch to power the drivers seperatly so i can switch from 100watt then to 250 watt,it has a 300 watt heater so i plan to power that on in the high power position.
« Reply #3 on: October 01, 2022, 11:02:59 pm »
That sounds pretty good. I'd still wonder about making it deeper; you've got plenty of power so why not accommodate larger items?
« Reply #4 on: October 02, 2022, 08:38:25 am »
its size is down to that being the biggest size tank i could find on aliexpress,would have gone bigger but that was the largest i could find,i think it holds about 15 ltrs approx of liquid,has a 300w heater pad too.
« Reply #5 on: October 03, 2022, 05:38:31 pm »
can anyone make sense of this chinglish  nonsense?,i am trying to work out the polarity of the tabs on the transducer but am not sure,any suggestions folks?.
Offline 1001
« Reply #6 on: October 03, 2022, 08:07:14 pm »
Positive terminal is between the two piezop rings, the negative terminal is the one connected to the metal part of the transducer, the two metal parts of the transducer are electrically connected to each other with a screw.
Online Halcyon
  • Global Moderator
« Reply #7 on: October 03, 2022, 10:39:58 pm »
I have banned tekguy from posting any further as he is the same person behind the user account m3vuv who was banned after repeated warnings. Since he refuses to discuss the matter and continues to play dumb, I'm left with no other choice.
The following users thanked this post: tekguy
