When you repair equipment that has shady capacitors that smell bad, and you replace them and clean the area around them, did you ever noticed effects from contamination?
Like it looks really clean, it leaked maybe 100 microliters or less of substance on the PCB near a power rail from a fatty 22000uF capacitor (hardly visible to naked eye but smelled like rotten dog shit). But, does this mean the entire meter has to be cleaned? It started to smell and was quickly turned off and maybe only powered on for like 4 minutes while smelling. I assume the capacitor broke then and there, and was not quietly shitting in the corner over the years because there was no smell. Or perhaps it was slowly gassing but not being heated enough to smell until the capacitor got to a critical point (does this stuff decompose with temperature)?
It is a LCR meter with a 1uA test current option, which is a bit noisy, but expected from the poor fixturing and lack of guarding. Don't know if I am chasing a stability ghost here. I can't take this thing apart easily and its just a over all pain in the ass and I feel crazy cleaning it because it looks nice??
I assume it won't be stable on the 10 microohm mark regardless of how clean it is unless you do a legit fixture and not 4 alligator clips on a bus bar. with 10 foot long probes.
Is a visual inspection with tilting to bright light enough to detect fouling? Can this stuff dissolve in contact flush (the good high pressure ones) (so I can just tilt the instrument over a garbage can and hose it down from above)? Or do I need scrubbing, ultrasonic, etc?
do capacitor electrolytes absorb in plastic and effect say temperature stability by messing with the material properties of expansion?
It was smelling after being powered on for a while, I don't know if that means it was increasing in pressure and venting already smelly stuff, or if it was breached and just venting stuff that smells at temperature. I threw out the capacitors already.
