The Mikroelektronika Botevgrad CM8001 (SM8001) is an SRAM with a memory depth of 256 bits. It corresponds to the Intel 1101A. The 1101 was the second SRAM sold commercially by Intel. Intel supplied an improved version with the 1101A. Like the 1101 and the 1101A, the SM8001 is based on PMOS transistors and therefore requires a +5V potential and a -9V potential supply. The 1101 still had to be supplied with 5V, -7V and -10V. The 1101A had been optimized to such an extent that it could work with 5V and -9V. The access time of the SM8001 is specified with a maximum of 1,5µs. By selection it was possible to stay below 1µs. The marking shows that the component was manufactured in 1977.
The die of the SM8001 has been placed far off-center in the package.
The dimensions of the die are 3,1mm x 3,3mm.
This image is also available in a higher resolution:
https://www.richis-lab.de/images/RAM/18x03XL.jpg (14MB)
800161 could be an internal designation.
In the center of each edge is a structure that shows how well the masks were aligned during production.
There are several test structures on the edges of the die. A resistor with a tap is integrated here.
These structures could be used to determine the leakage currents between the lines in the substrate. They could also be used to measure the parasitic capacitance.
The SM8001 is still based on a metal gate process in which the metal layer represents the gate electrodes of the MOS transistors. Where the metal layer is supposed to act as a gate electrode, there is a window with a gate oxide, a very thin silicon oxide layer in the thick, so-called field oxide. Intel has already manufactured the 1101 and the 1101A using a more modern silicon gate process. The polysilicon gate electrodes make it possible to produce more precise geometries.
The source and drain areas of the transistor integrated here are difficult to recognize. In other areas, the structures are more clearly visible. On the right, a resistor leads to a fourth testpad. The contact between the resistor and the drain/source area appears to occur without a special contact window.
Another test structure can be used to measure a parasitic MOSFET. This is a metal line that covers an insulation area between two lines in the substrate. Due to the thick field oxide, the charge of the metal line has a significantly lower influence on the underlying structures.
The functionality of the SM8001 is very clear. The address lines A0 to A3 are buffered, decoded (red) and finally activate one of 16 columns in two memory areas (yellow). The memory is divided into two blocks, each with 16x8 memory cells. The address lines A4 to A7 are also decoded (blue) and then select one memory row (green). Two lines run in the line selection area, which either transmit a differential signal to the respective memory cell or forward the state of the memory cell to the circuit in the upper left area.
The input buffer (pink) and the output driver (purple) are located in the upper left area. Both circuits are connected to the chip select and the R/W input. Like the 1101, the SM8001 also offers a complementary output to the data output. The two large push-pull output stages are clearly visible. In addition to the positive supply potential Vcc and the negative supply potential Vdd, the memory also has a Vd contact. Vd must also be connected to -9V and supplies the input and output circuits, while Vdd supplies the memory area itself.
The regular structure of the memory area is clearly recognizable. It consists of blocks, each containing two memory cells.
There is a Vcc line below each memory cell. The Vdd potential is located at the top and bottom. These Vdd lines are also used by the memory cells at the top and bottom. The word lines, which activate the corresponding column of the memory, run to the right and left of the two memory cells in the substrate. The two horizontal bit lines transmit the status of the selected memory cell.
The SM8001 is based on 4T memory cells containing four PMOS transistors and two resistors.
https://www.richis-lab.de/RAM15.htm
