PCB quote
Author Topic: Understanding my own design - moisture detection circuit  (Read 504 times)
Offline Tonkabot
« on: August 08, 2022, 04:01:16 am »
I have this circuit I desiged that tells how much resistance there is between the connector (both contacts are connected to one sense wire) and ground.
Then, if the test point (a brass elbow in a co2 gas stream) gets wet (blood, most likely), we know the machine has had a biological contamination.
So normally the ADC pin (A1_Fluid_Sense) reads about 32000 When J5 sensor is hooked up and open.   it reads 38000 or so when J5 is open.
it will read 0 if you dead short it to ground.
My problem is that D34 is getting blown.    it is just a sod-323 shottky.   I had thought that some transorb or something would be more appropriate there, but I never did figure out something that worked.   The intention of D34 was to be like a 5v transorb, but I couldn't get that to work.  We need to keep the ADC pin safe from any crap that might blow the processor.
D34 has not blown much (I think about 3, over a year of 200 machines running), but that is too much.
Oh, Vusb is 5.2volts.
[attachimg=1]
Not sure I am getting the schematic png attached...
« Last Edit: August 08, 2022, 04:41:03 am by Tonkabot »
Offline ConKbot
Re: Understanding my own design - moisture detection circuit
« Reply #1 on: August 08, 2022, 08:27:29 am »
Is ESD building up from a dry gas flowing? The diode should be sufficient for charge on the wire itself, but is a nearby sections of plastic tube charging up and then discharging into the sense wire?
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: August 08, 2022, 12:39:01 pm »
Try a larger diode and add a 1k resistor in series with pin 1?
Offline Tonkabot
« Reply #3 on: August 08, 2022, 02:44:19 pm »
I didn't think there could be a static build-up because there is only 75k to the 3.3v rail and 100k to the 5.1v supply.   I'm thinking that that should eliminate a static potential build up.
Brynn
Offline Tonkabot
« Reply #4 on: August 08, 2022, 02:57:28 pm »
The client is pretty resistant to making board changes...   However it would be pretty simple to incorperate a series resistor in the sense wire harness, and I don't see any drawback to making such a change permanently.   I'll be trying that out, and it seems like it will help protect the diode on the board.
Brynn
