Hello,
I am using a Solenoid in an application, but I am unable to understand specifications mentioned in the datasheet of solenoid.
Below is the link of the product I am referring to. All the product specifications such as duty cycle and Force-stroke curve can be found in the link.
https://www.takaha-japan.com/product/cb0730/In my application,
On Time is 150 ms and Off Time is 10 sec.
Voltage Available to power Solenoid - 6 V
Please answer below queries
1) Can I apply 6V to Solenoid for above mentioned Off Time and On Time ?
2) If yes, What is the Solenoid force if I operate Solenoid with above conditions ? Also please explain how did you find out Solenoid Force?
Awaiting for reply.
Thank you in advance.
