Hi there,
the supply of my K40 Laser crapped out so i wanted to take the opportunity and upgrade the electronics.
The original configuration uses a potentiometer connected between +5V and GND and the wiper is connected to the "IN" labeled pin on the PWR-Supply. Since the "Datasheet" of the supply states that also a PWM could control this input i did hook up a PWM-Out to this pin.
Now i could notice that this "IN" puts out 5V. Confused as i am i took the thing apart and here i am even more confused asking if someone can explain what is happening here: please have a look at "sch.png" in the attachements.
The Chip used is a TL494CN which error amplifiers are used and hooked up to this Input. It's Datashet shows no internal connection to "3" the output, nor can i find a connection elswere on the board made to "3". Which input could possibly be on "1" that this makes sense? I do have to miss a connection internally or externally right?
Thanks for having looked in here
and thanks in advance for your help.
