Hello mates,
a customer has a series of underwater clamshell, it takes iron oxide out of a tank with industrial water.
With the clamshell there is a underwater 3 phase 25HP hydraulic pump, the current is up to 25A. The pump is reversible, forward the oil feeds the clamshell opening and reversing the motor closes the shells.
In resting position cable length is around 3m and the deepest it can go is around 12m, being 5 underwater. The iron residue and water level changes a lot
Nowadays a standard IEC 60309, 4 poles, 32A is assembled inside a steel tube, sealed with an excess of screws and nuts.
Maintenance team try to improve the sealing by using a big amount of industrial silicone, it fails in just a few days
Dirty water gets in with iron chips, mixes with hydraulic oil damaging the pump, valves, pistons seals or gives the exposed motor windings low insulation tripping the VFD
The cable is a 4G4, the outside diameter varies from 12 to 18mm and is unwind from a spring cable reel
This improved version would still use a steel flange, with improved gasket and a locking nut for easy of maintenance.
The challenge is how to proper seal the cable? Cable glands have been used but they fail in one or two weeks.
I tried to locate underwater connectors but no source have been found.
Greetings
