Author Topic: Unidirectional TVS on I2C prevents it from working - Bi-directional one is ok  (Read 5651 times)
Offline ricko_ukTopic starter
(Updated with the part numbers and details about the voltage/length. See underlined addition)
we have a board manufactured for years and always worked. On the I2C channel there are two separate connectors so we had two "dual TVS", one on each connector protecting both the SCL and the SDA lines.
The original TVS were the PESD3V3L2BT for some reason bi-directional (not required because I2C only needs unidirectional). We recently changed it to PESD3V3X2UT a uni-directional and some boards stopped working but when we remove it they work perfectly.
The Ir" is running at 400KHz. The system and the I2C run at 3V3. Both connected like in the attached screenshot. The I2C and the 3V3 lines are clean and stable.
The I2C is on the PCBs only connected by a ribbon cable 3 inches long. The external I2C connector does not have anything connected to it, not even a cable.
Waiting for a PCB so I can have a look at the signals but any ideas/suggestions what could cause the intermittent faulty behaviour on the I2C channel with the new (uni-directional) TVS?
The capacitance in the new one is extremely low (less than a pF) compared to 100pF of the original, so that cannot be the reason.)
This is the PESD3V3L2BT, the original (bi-directional) which worked well for years: https://assets.nexperia.com/documents/data-sheet/PESDXL2BT_SER.pdf
This is the PESD3V3X2UT which, when used in place of the original one causes some PCBs to not be able to communicate with the I2C ICs: https://assets.nexperia.com/documents/data-sheet/PESD3V3X2UT.pdf
Thank you :)
« Last Edit: March 02, 2022, 02:37:32 pm by ricko_uk »
Screenshots attached of the original and new TVS types (both connected as usual as shown)
Online m98
Just shooting in the dark, could the ground potential at the diode float higher than the signal voltage for some reason? Are there some high current paths on your PCB?
Offline uer166
Check the footprint pinout, potentially you've flipped some pins on the TVS. If it's bidirectional, the breakdown from any pin to any other pin is >3.3V, so even if you screw up it'll keep working. No longer the case with 0.7V drop.
The following users thanked this post: EEEnthusiast
Offline AndersJ
OP is not saying which type is used when it works.
Most likely the clamping voltage is lower for the non working alternative.
"It should work"
R.N.Naidoo
Offline T3sl4co1l
    • Seven Transistor Labs
Is it exposed to more than 3.3V?  Is there any ringing on the line?
Most importantly -- why is I2C being exposed on a connector!
I would stick with the traditional zener type TVS.  If nothing else, the capacitance gets you a bit more filtering (may want to add ferrite beads or other additional filtering to this end), and a mild resistance (say 10-100 ohms) toward the driver(s) increases ESD immunity at the expense of drive strength (which should be irrelevant as, it's I2C, it's not supposed to run any kind of length).
Seven Transistor Labs, LLC
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
OP give us the exact part numbers please ;^)
Offline Berni
  • Country: si
Leakage can also be a problem sometimes.
The more zenner kind of protection diodes have a pretty soft knee at these low voltages, so they can leak a significant amount of current in the area before the actual breakdown voltage. On a I2C bus that is only pulled up by resistors this could pull the bus down slightly.
On the other extreme there are TVS diodes that operate more like a Diac where they have excellent low leakage up to a point where they trip and they start pulling current until the voltage drops sufficiently low to let it relax again. This can be a issue on I2C that has constant pullup resistors.
And as others said running I2C on a cable outside of the device is usually a bad idea. I seen I2C be finicky even between chips on large PCBs.
Online NiHaoMike
    • Facebook Page
That's done on every HDMI link and it works just fine, although the cable is shielded.
The following users thanked this post: wraper
Thank you all! :)
Replies below to various questions/comments:
Is it exposed to more than 3.3V?  Is there any ringing on the line? Most importantly -- why is I2C being exposed on a connector!
@Tim,
it is not exposed to more than 3V3 and no ringing. Why would the I2C being exposed to a connector be a potential issue in general?
By "traditional zener type TVS" do you mean to use an actual Zener instead of a TVS?
@ANTALIFE,
parts updated also in OP. The one that worked (bi-directional) is PESD3V3L2BT and the one that only for some boards did not work was the uni-directional PESD3V3X2UT. So both parts are rated for Vrwm = 3.3 V and the entire system runs at 3V3 only.
@Berni,
why is an I2C cable outside an enclosure a potential issue?
Thank you
« Last Edit: March 02, 2022, 05:01:11 pm by ricko_uk »
Offline T3sl4co1l
I2C on connector is bad for EMI and ESD.  Fine if well shielded (as the HDMI example (Display Data Channel (DDC)), also used in VGA and DVI -- all use shielded connectors and cables), but the low bandwidth may give the false impression that it doesn't matter.  But there's hardly anything special about I2C transmitters or receivers; there's a minor amount of filtering (maybe 50ns worth) and that's about it.  Extra transitions corrupt the state easily, pins don't have extra robustness towards ESD, and EMI banging into ESD clamp diodes shifts the baseline which can also corrupt logic levels, even if the RF isn't being read directly as signal.
Besides, it's no good for long cable runs, not that that's relevant here I guess, but cable length is an easy way to soak up extra loading capacitance compromising clock rate.
Finally, it's not easy to filter, because the impedance isn't constant.  You want to minimize loading capacitance, but you can't get the cutoff frequency very low just by increasing inductance: when a driver pulls down, it'll ring (because R(driver) < filter Zo), and then when driver(s) turn off, it'll rise slowly again -- the edges are asymmetrical, which I mean, you already know this, but trying to put a filter on it just doesn't work very well for the same reason all over again.
It truly is well suited to exactly what it is -- onboard communication!
There are extenders and translators out there, if you absolutely need to use it over longer distances (e.g. differential I2C, which physically works something like CAN, but it's the same old I2C protocol)... or there are other standards to choose from. :)
As for TVS, the regular kind is just a zener, a beefy one that's rated for surges.  You can indeed use regular zeners, if appropriately rated; they might not be, so it's simply safer to get the TVS version.  They might well put the same chips into both products, give or take appropriate testing; who knows.
There's also the snapback diode (the unidirectional one).  This has a negative resistance characteristic, and, it's not clear if it'll turn off with the pullups in there; they don't specify the valley (turnoff) current or voltage.
You'll also see low-capacitance TVSs, which are of the usual (zener) type, but have a series diode so that the TVS capacitance charges up to signal peaks, only loading the signal initially.  Often the TVS comes out on a pin that can be tied to VDD, so it stays out of the way normally, and also protects VDD.  See dual and quad arrays for USB and such.
The other kind of negative resistance TVS is the SIDAC type, which has low leakage until breakdown, then stays latched on until holding current is released.  Advantage of course being much higher surge energy handling for a given voltage rating.  They aren't available at such low voltages though (I think?).
The following users thanked this post: AndersJ, ricko_uk
Offline Berni
  • Country: si
@Berni,
Thank you
Some I2C chips and MCU peripherals can get confused into weird states if they see a voltage spike on the lines. At the same time the bus is only driven high by a pullup so it is more sensitive to extra capacitance on the lines (long cables can have quite a bit of it)
Not saying it can't be done, just that some care has to be taken when doing so. Like short shielded cables with consideration to there capacitance.
Thank you Tim and Berni :)
Offline Scutarius
Hi ricko_uk
Just wondering if you ever found out the root cause?
Sorry for the late reply but took several months off.
Kind of... that behavior apparently was shown in one of the graphs's curves. You can barely see it that after clamping it goes back to a voltage lower than the initial (rated) one.
But it was not clear why it kicked in in the first place because even the manufacturer's tech support replied saying that it should not have kicked in in the first place (the voltage never overshot over the triggering voltage).
Online Doctorandus_P
I am wondering about your choice for unidirectional TVS'.
As long as the signals stay on the PCB, then you don't need any extra TVS diodes, and when you connect it with a connector to the outside world, then the polarity of ESD events is unknown.
Edit: Oops, silly me. As Langwadt mentioned below, unipolar TVS also works as a normal diode.
« Last Edit: May 23, 2024, 04:34:00 am by Doctorandus_P »
Offline T3sl4co1l
Was this hot-plugged at all?  Or firmly seated and only then power-cycled?
Online langwadt
a unidirectional TVS is a regular diode it the other direction
Offline PCB.Wiz
If it was a thyristor-type trigger TVS, maybe it has a dV/dT trigger, like triacs do ?
Many are designed for protecting rails, not signals,
Offline T3sl4co1l
Sort of. It's a snapback diode.  It's sort of like a zener that has BJT avalanche-discharge (punch-through) behavior.  Or perhaps other designs, I'm not sure.  Not dV/dt AFAIK.  The important part is, like the thyristor, there's a hysteresis loop with some breakdown voltage, peak roll-over current, and valley voltage and current.  Unlike the thyristor, they don't specify these... ::)
It was firmly seated and only power-cycled. that is why it was weird that it kicked in. But since then I changed it to a "classic" type and it works as expected.
Offline PCB.Wiz
Yes, data is vague.  I was musing if one could make an oscillator using these   8)
This is AOS data, for their new low C TVS diodes in teensy packages, they do include curves, but no mention of HOLD current.
« Last Edit: May 23, 2024, 02:45:32 am by PCB.Wiz »
Offline Berni
  • Country: si
You can still get brief spikes during power cycling.
It is possible for power regulators to slightly overshoot on startup because the regulation loop doesn't handle the surge of filling capacitors at the start.
It is also possible to get large voltage spikes above the supply voltage when hard switching the power via switch contacts and having a long power cord. The initial surge in current from filling caps stores some energy in the inductance of the cable that then kicks back and causes a spike upwards in voltage.
If you are particularly unlucky it is possible for these spikes to fry something on rare occasion. This is a nightmare to debug because it just happens randomly after like 10 to 1000 power cycles, you can't capture what happened, you are just left staring confused at the blown chip when it does.
I guess just putting an inrush current limiter, or just an inductor in series at the regulator output, might be a general simple and cheap solution to avoid that. Any other ones too?
Offline Berni
  • Country: si
The solution for avoiding that tends to be the use of EMI ferrites to burn off the pulse energy into heat, and avoidance of using high Q capacitors on the input (like most MLCC capacitors)
Similar can be used around regulators to limit how sharp of a current the regulator is exposed to. Otherwise softstarting a regulator is also a good idea
