I have troubles with my lm2596 power supply. I have this circuit on a pcb and it doesn’t work. Tried different inductors, two types of diodes,... I soldered the components together with a few wires to know if there’s a problem with my pcb... but the output voltage is also just below the supply voltage...
Output C = 680uF en load =39 OHM
