Author Topic: Upgrading eMMC and RAM of Chromebook possible?  (Read 4344 times)
Offline FrankETopic starter
« on: April 02, 2020, 03:11:00 am »
I've a Chromebook which came with 32GB eMMC and 4GB soldered-in SMD RAM.
I've flashed it with a full Mr Chromebox BIOS and installed GalliumOS on it.
Acer C730 Gnawty aka Chromebook 11. Bay Trail
It's currently being used as my main computer while waiting for a replacement PSU for my desktop.. It's usable as long as I use hook it up to a proper monitor and use a wirless keyboard and mouse but it can't do anything remotely demanding
If I can source an eMMC with the same pinout and RAM with the same pinout would it just be a straight swap?
IIRC when I briefly looked into this before the devices are by Hynix.
The desoldsering and soldering isn't the issue - I've no idea how the memory is addressed on this thing.
sudo lshw -c memory
[sudo] password for **
  *-firmware
       description: BIOS
       vendor: coreboot
       physical id: 0
       version: MrChromebox-4.9
       date: 01/04/2019
       capacity: 8128KiB
       capabilities: pci pcmcia upgrade bootselect acpi
  *-memory
       description: System memory
       physical id: 1
There are all sorts of loops for the audio to work.
df -H
Filesystem                      Size  Used Avail Use% Mounted on
udev                            2.1G     0  2.1G   0% /dev
tmpfs                           406M  1.6M  404M   1% /run
/dev/mapper/galliumos--vg-root   30G  6.9G   22G  25% /
tmpfs                           2.1G  302M  1.8G  15% /dev/shm
tmpfs                           5.3M  4.1k  5.3M   1% /run/lock
tmpfs                           2.1G     0  2.1G   0% /sys/fs/cgroup
/dev/loop0                       51M   51M     0 100% /snap/gtk-common-themes/1474
/dev/loop1                       78M   78M     0 100% /snap/wine-platform-3-stable/6
/dev/loop3                       29M   29M     0 100% /snap/snapd/6953
/dev/loop4                       58M   58M     0 100% /snap/core18/1705
/dev/loop2                       26M   26M     0 100% /snap/snapd/6434
/dev/loop5                      4.2M  4.2M     0 100% /snap/notepad-plus-plus/227
/dev/loop6                      238M  238M     0 100% /snap/wine-platform-runtime/104
/dev/mmcblk0p2                  739M   51M  635M   8% /boot
/dev/mmcblk0p1                  536M  9.8M  527M   2% /boot/efi
tmpfs                           406M  8.2k  406M   1% /run/user/1000
Offline amyk
Re: Upgrading eMMC and RAM of Chromebook possible?
« Reply #1 on: April 02, 2020, 01:46:50 pm »
For RAM, it should work unless the BIOS was hardcoded to a specific size, and/or the CPU physically doesn't have the address lines to support the larger size.
For eMMC, it's a little more flexible but beware of features like password protection and such which tie the contents to another unique ID on the motherboard.
The following users thanked this post: FrankE
Offline magic
« Reply #2 on: April 02, 2020, 06:37:27 pm »
I don't think the Chromebooks use any security features of eMMC. They have a software security architecture which verifies if the code running on the machine does indeed come from Google and that's about it. Last time I looked they didn't even encrypt user data. And if they did, I expect that Google wouldn't trust eMMC vendors and would roll their own.
As for RAM, the magic word is "SPD" (serial presence detect). It's an I2C EEPROM with information about the memory, normally present on each DIMM. If this is present on the motherboard, you will need to reprogram it with information about new RAM. No rocket science, you take some numbers from the DRAM datasheet and encode them per the SPD spec. If it is not present, and I expect that this is the case, then the information must be stored in the boot ROM and you will need to write-unprotect the machine and modify it. RAM chips by themselves offer absolutely zero autodetection functionality.
It seems you have Linux on that thing, can you run i2cdetect -l for starters?
« Last Edit: April 02, 2020, 06:40:37 pm by magic »
« Reply #3 on: April 02, 2020, 09:14:22 pm »
Yes I put a MrChromebook BIOS on it and Gallium OS
sudo apt-get install i2c-tools
i2cdetect -l
i2c-3   unknown      i915 gmbus vga                     N/A
i2c-1   unknown      Synopsys DesignWare I2C adapter    N/A
i2c-8   unknown      DPDDC-C                            N/A
i2c-6   unknown      i915 gmbus dpb                     N/A
i2c-4   unknown      i915 gmbus panel                   N/A
i2c-2   unknown      i915 gmbus ssc                     N/A
i2c-0   unknown      Synopsys DesignWare I2C adapter    N/A
i2c-9   unknown      DPDDC-B                            N/A
i2c-7   unknown      i915 gmbus dpd                     N/A
i2c-5   unknown      i915 gmbus dpc                     N/A
Offline magic
« Reply #4 on: April 03, 2020, 06:44:09 am »
Hmm, not sure which of those (if any) would be the main SMBUS. But I will tell you what, I suspect the SPD data are embedded in the boot ROM anyway. See if you can find any EEPROM chip on the board or a leaked schematic of the laptop (those are surprisingly common, actually).
edit
Or look for the source code of ChromeOS boot firmware for your platform. It will probably contain the SPD or some placeholder for it or other indication that the thing should be present. Maybe you will find some discussion on mailing lists, bugs or places like that. Or maybe you will find a confirmation that they use a separate I2C chip on the board, but why would they bother?
« Last Edit: April 03, 2020, 06:51:39 am by magic »
Offline mikerj
« Reply #5 on: April 03, 2020, 01:07:25 pm »
Writing and reading back a pattern would seem to be a simple autodetection method that needs no SPD to determine address range.
Offline magic
« Reply #6 on: April 03, 2020, 07:05:27 pm »
Yes, but it's not so simple with timings. In practice SPD is a necessity, therefore it's always provided, therefore no BIOS performs attempts at autodetection.
