Author Topic: Measurements on Usb Killer V3  (Read 1738 times)
Offline newbadboyTopic starter
« on: May 17, 2017, 09:10:57 am »
Seen a lot of talk regarding this gadget but not anyone that actually has measured on it. So have done some  :box:
And the results are bad news!
I have used a high voltage diffprobe so all amplitude values are x100 times.
Measured with no load, 4ohm load and 100ohm load. Results can be seen below
Burst frequency=8Hz
Internal burst frequency=1kHz
Falltime=260ns
Risetime=4.8us
Pulsewidth=16,7us
Amplitude=226Vpp
Amplitude inc undershoot=348Vpp
Re: Measurements on Usb Killer V3
« Reply #1 on: May 18, 2017, 11:23:33 am »
Apparently can Macbook pro handle this, anybody having some info on how they have solved this?
