Author Topic: Altium 500 Clearance errors, NONE correct  (Read 561 times)
Offline ricko_ukTopic starter
« on: December 04, 2024, 12:14:05 am »
could someone please help with this, in 20 years of using Altium it never happened before and could not find any solution. It is very urgent because needed to send off to manufacture yesterday under massive pressure from the customer because it costs thousands of pounds every day of production being halted.
I am using Altium 21 and I have been routing the PCB all along with only one single clearance rule which is set to "all to all" and to a value of 0.15mm for all items and it works while routing (and I can also see the routing boundaries while routing) and they have been always respected automatically (while interactive routing it would not get closer than the allowed boundary gap of 0.15mm). So I routed the entire PCB.
Screenshot of the Clearance rule setup is also attached.
When I ran clearance error check at the end, as you can see from the attached screenshot, it brings up 500 clearance errors (it stops at 500 because that is the limit set but it might highlight many more, perhaps the whole PCB) but none of those are less than 0.15mm (and by far !!).
I reused a previous Altium PCB file (from a completed project) and the original one does not have any such errors (and never did).
Any idea how to fix it?
Thank you as always!!  🙏
« Last Edit: December 04, 2024, 06:52:13 am by ricko_uk »
Offline Benta
Re: URGENT HELP PLEASE: Altium 500 Clearance errors, NONE correct
« Reply #1 on: December 04, 2024, 12:21:25 am »
« Reply #2 on: December 04, 2024, 12:26:33 am »
Thank you Benta,
unfortunately don't have an active subscription.
Thank you
Offline Electro707
« Reply #3 on: December 04, 2024, 01:19:40 am »
try changing "Any Net" to "Different Nets Only" in your clearance rule
https://www.altium.com/documentation/altium-designer/pcb-electrical-rule-clearance?version=18.1#constraints
It is also odd that the collision rule is stating "<0.11mm" while your clearance is set at 0.15mm. A small observation.
« Last Edit: December 04, 2024, 01:21:53 am by Electro707 »
« Reply #4 on: December 04, 2024, 02:17:07 am »
Thank you Electro707,
Changing that to "Different Nets" removed a lot of them, but still 137.
Yes, unclear why it shows that when the rule is set to 0.15
Thank you
Offline moffy
« Reply #5 on: December 04, 2024, 02:55:45 am »
The fact that it is mentioning 'ARC' is it between an overlay and a track? If so it's not really a problem.
« Reply #6 on: December 04, 2024, 04:15:20 am »
Thank you Moffy,
they are tracks from "rounded" length tuning.
Thank you
Offline moffy
« Reply #7 on: December 04, 2024, 05:22:15 am »
I assume that the highlighted green parts are the errors, that's how they show up in my version of Altium. When I get continuous tracks that are part green I check that the sections are the same 'net' identifier, sometimes you get a 'no net' section connected to a named net and the ERC throws an errror.
Offline temperance
