Author Topic: USB 3.0 C socket Superspeed with no flipping feature  (Read 602 times)
Offline nachus001Topic starter
  • Country: ar
« on: January 04, 2024, 01:19:59 pm »
Dear all:
I have a question. I have to make a design with and USB 3.0 socket, and the design needs to work with Superspeed USB3 capabilities
but, due to space limitations, I cannot add a USB3 UFP mux chip (HD3SS3220, PI5USB30213A and the likes)
However, I would't have problem losing the connector flip ability, if I can retain the Superspeed capability.
I've implemented USB2.0 functionality using USB3-C sockets in the past and they worked like a charm. Flippable and not flippable implementations
My question is if a superspeed USB3.0 interface can work at Superspeed in only one connector position without having problems or defaulting to an USB2.0 connection.
I've read the USB documentation (lightly I have to admit) and it doesn't says nothing about this one. I guess this is kind of a hack.
Do you have any experience in this kind of "partial" implementations? Thx in advance
Cheers
Nachus
Online wraper
  • Country: lv
Re: USB 3.0 C socket Superspeed with no flipping feature
« Reply #1 on: January 04, 2024, 01:37:00 pm »
The workaround to not have mux chip is only possible if the chip you want to connect to USB-C connector has two separate USB3.0 interfaces.
  • Country: ar
« Reply #2 on: January 04, 2024, 02:29:14 pm »
Hi Wraper
I need two interfces even if I don't need the plug flip capability? I need the interface to work with the connector in one position only.
Nachus
