Hi perhaps some of you diehards have seen this before, I haven't and am greatly surprised.
Today I opened a commercially available device that I got from a friend: a Meanwell DAP-04 protocol converter.
To my surprise 19 pins on the LPC1114F microcontroller were unsoldered.
Those pins had no pads under them just soldermask so they are totally clean and are mechanically floating above the pcb.
Why?
The only reason I can think of is to save $0,001 on solderpaste.
The drawback is that the uC is less stable attached to the pcb, and hopefully those pins are defined as output low else if they are defined as floating input it can destroy the uC.
Has anyone seen this before and have a viable explanation why a decent manufacturer like Meanwell would do something like this ?
Sorry the picture is not better, I do not have a foto option on my stereo microscope and the macro setting on my camera would result in less detail, hope you can see it clearly.
