Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Source a transformer with multiple secondaries
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Source a transformer with multiple secondaries (Read 1181 times)
MarkF
Super Contributor
Country:
on:
January 07, 2019, 06:17:10 pm »
I would like to build a simple linear power supply with three outputs (i.e. 5VDC, +12VDC and -12VDC).
I want to keep the 5V GND independent of the +/-12V GND. Only looking for a 1A capability max on each output.
Does anyone know where I can find a single transformer with three secondaries instead of two transformers?
Last Edit: January 09, 2019, 01:43:21 pm by MarkF
Logged
schmitt trigger
Super Contributor
Country:
Re: Source a transformer with multiple secondaries
Reply #1 on:
January 07, 2019, 06:25:40 pm »
Perhaps the easiest would be to purchase a toroid transformer which can provide the +/- 12v supplies, and then hand wind your own winding for the 5v supply. Window area allowing it, of course.
Logged
station240
Supporter
Country:
Reply #2 on:
January 07, 2019, 06:57:22 pm »
You can get multitap transformers, been out for decades.
I have no idea where you get them in the US, all the electronics stores in Australia sell them.
Try searching ebay for "transformer 9V+9V 15V+15V", seems to be some usable results there.
Logged
MarkF
Benta
Super Contributor
Country:
Reply #3 on:
January 07, 2019, 07:22:12 pm »
Or just get it made to order. No big deal nowadays. There are transformer companies that'll make one-offs. Search the interwebs.
Last Edit: January 08, 2019, 03:52:17 pm by Benta
Logged
MarkF
Zero999
Super Contributor
Country:
0999
Reply #4 on:
January 08, 2019, 09:34:45 am »
Digikey sell them but the power rating for the 12V secondary is a bit less than your requirements, at only 250mA.
https://www.digikey.co.uk/product-detail/en/signal-transformer/14A-30-512/595-1705-ND/1117954
How about using two transformers or a switched mode power supply for the 5V part, which presumably isn't so sensitive to noise and ripple?
Another option is to use a transformer with two secondary windings with one connected to a voltage doubler to get the +/-12V, although it would need to be considerably over-rated.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
