Hi
Without buying one of the specific parts and testing it, there is no way to be sure of it's efficiency. There is no basic reason why a properly designed converter would *not* be above 80% efficiency. If you need better than that, shopping for random parts is probably not the best way to get the job done. To me the bigger issue is that you say you need 34V and the unit you are looking at is only good to 30V max....
Bob
