I got the idea to make a color organ recently. I am done with the design and simulation of it and am going to go into PCB design now. Before I do this I would like to get some feedback on the design to see if I made any mistakes. I attached the schematic, the way the circuit works is it takes the signal from the headphone jack and amplifies it by 10. It is then filtered by the three active bandpass filters which is then used to drive the darlingtons on the output.
A few notes:
1.) This is not very efficient, I know, I plan on implementing an LED driver board later.
2.) I am using Darlingtons because I want to use this with 1W RGB LEDs.
