The LM394 datasheet only claims four decades range for that circuit, and elsewhere it notes that most datasheet parameters are guaranteed from 1uA to 1mA Ic, which implies only a three decade range with guaranteed accuracy.
I don't have your transistor or OPAMP models, but doing a .dc sweep over a carefully chosen six decade range:
.dc dec V4 30u 30 50using the generic UniversalOpamp2 model with its default parameters and any small signal NPN, gives very close to a straight line for six decades - far better than I suspect you'll achieve in real life. Remember all LTspice components default to being 0% tolerance, and most to being ideal.
