I don't really have enough expertise to explain this very well but if you look at the datasheet
http://www.onsemi.com/pub_link/Collateral/LM2576-D.PDF
Check figure 25 and the blurb around it as it discusses this
I am using a low ESR (38 milliohm) 1000uf 25v capacitor and a 220uh toroidal inductor that is good for 10 amps (all I had), also I have made sure to keep the layout tight and was careful about the current paths.
All of the input and output sections share a star ground at the IC's ground pin where there is another low esr input capacitor in parallel with a .1uf film cap for bypassing.
It all starts with analysing the circuit and predicting the control - output transfer function. From this you can determine how to counter the gain and phase so that you cross over the 0dB line at a -20dB/decade slope with 60 degrees of phase to spare.
To test you have to place a dynamic load on the output and switch between 10% and 90% load. Using a scope (AC coupled) you monitor the transient response of the output voltage.
This will tell you whether the control loop is underdamped or overdamped. Standard control theory applies.
Try to aim for a phase margin of about 60 degrees. Gain crossover frequency can be about 5-10% of switching frequency.
Dick
Thanks, so I am looking at the brief drop that occurs when the load current changes?
If so then this is what I have got so far (no feedforward capacitor).
50mV/div 100uS/div
I am not sure if this is considered bad or acceptable. That ripple can be seen as this chip only switches at about 50khz.
