Author Topic: Strange analog circuit problem with grounding  (Read 2022 times)
Offline Mad IDTopic starter
« on: January 22, 2014, 09:49:19 am »
Hello,
I have developed an FSK (HDX) RFID reader which works great when it is powered by a clean isolated lab power supply. The reader has a buck converted at the input. If I ground the lab power supply it works the same.
However, if I power it through an isolated low quality 12V wall adapter which is very very noisy my RFID reading range falls to 1cm. What I have noticed it that the noise itself is not a problems, it's the fact that it is isolated + noisy in combination!
When I ground the system the reading range goes to normal regardless of noise. If I try to probe my analog signals with a non-isolated scope, as soon as I touch the signal ground with scope ground problem is of course gone.
Please help, I want to understand the problem so that I can avoid it in the field.
Cheers.
Re: Strange analog circuit problem with grounding
« Reply #1 on: January 22, 2014, 12:53:03 pm »
New info, ground potential difference between earth ground and crap power adapter is 85Vrms AC.
This is the problem definitely, still not sure why this would be a problem for RFID communication. So my reader antenna is changing potential to ground at 50Hz rate. Anyone?
Offline poorchava
  • Troll Cave Electronics!
« Reply #2 on: January 22, 2014, 06:34:19 pm »
Have you torn apart the adapter? Maybe it's the parasitics in the adapter that cause this problem?
