Author Topic: Servo Controller Board with 2 Power Supplies  (Read 2493 times)
Offline buttersTopic starter
« on: August 14, 2010, 11:26:51 pm »
Hi guys, I've been working on this board for awhile now and it's basically designed to control a quad 2-input multiplexer (74AC157MTC) to switch between an external set of servo control signals (coming from another board) and servo control from the on-board ATMega1281.  The board has to be reduntantly powered (it's essentially a failsafe system) with its own little battery (I'm gonna use a single cell LiPo), but I am at odds with how to deal with the servo power lines.  The servos are powered by their own high-capacity 5V NiMH battery and will pull quite a few amps at times.
I initially thought that I would be able to power the servos seperately from the board with their own battery as long as I keep a common ground between the two voltage sources, however some preliminary testing is suggesting that this won't work.  Is having the servo control signal driven by a different voltage source from the servo power source going to be an issue when I try to control the servos with the on-board microcontroller?
Offline RayJones
    • Personal Website
Re: Servo Controller Board with 2 Power Supplies
« Reply #1 on: August 15, 2010, 12:22:43 am »
By the "servo" I presume you mean the model type with a nominal 1.5ms PWM control?
There are many and varied servo systems in the world  ;)
If so, obtaining a PWM signal from another system will not cause an issue, so long as your grounds are commoned.
You could use an opto coupler if you really desire isolation...
