Author Topic: Using TL084 or TL074?  (Read 16898 times)
Offline gbowne1Topic starter
« on: May 17, 2010, 02:05:20 am »
Hi all!  What would help me figure out which TL074 or TL084 to use?
Looking at the data there is a lot to choose from to narrow it down.  But I got a little lost in the datasheets.  I've used other TL0** type IC's but this pair is a little confusing.
They are opamp IC's of course.. so they have a +4v/-4v input rail and seem to be a 70 to 80db Common Mode Rejection Ration (CMRR).
Voltage and Bias current @ 15v w/ different values.
The application needs a 14pin package.
They both come from STMicro or TI.
Greg
Offline allanw
    • Electronoblog
Re: Using TL084 or TL074?
« Reply #1 on: May 17, 2010, 02:59:13 am »
Dunno if you saw this, but TI's site says "TL081 - Similar parts, where TL08x is a general purpose family and TL07x is a low noise family"
« Reply #2 on: May 17, 2010, 03:21:06 am »
No. I didn't see that.  Low noise would be nice.  It's an RF Application.
Offline tecman
« Reply #3 on: May 19, 2010, 11:20:32 pm »
RF should mostly not be related to the op-amp.  The low noise refers to internally generated noise in the op-amp.  The op-amp noise will be much lower in spectrum than RF.
If you are working in mV signals, lo noise can be a benefit.
Paul
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #4 on: May 20, 2010, 12:35:16 am »
The gain-bandwidth product on the TL08x is only 4MHz anyway. That is to say at 4MHz, max gain is 1, 2MHz it is 2, 1MHz it is 4 etc. There are RF op-amps, but that isn't one.
« Reply #5 on: May 22, 2010, 01:45:13 am »
Project: RF Power Amplfier for 87MHZ - 108MHz FM
Output Min.: 500w ERP
Output Max : 700w ERP
RF Input @ drive: 7w
Thinking about using a BLF278 by NXP Semiconductors they are about $150.
Or maybe one of the MRF transistors.
GReg
