Why not just post the netlist?
Seriously, you have USB_PORT_D_N label right next to a USB_PORT_D_N label! Just join the things up and then you can visually see that the former is joined to the latter. As it is, you have to read the damn label and then go looking for where (on the entire sheet) it might be used.
Similarly, where the Vin 5V meets the USB 5V it would be more obvious what's going on if it were actually visually connected. You can still put boxes around the appropriate parts, but for pities sake joined up the dots.
