Hello! I am new here, and fairly new to electronics. I have no formal education, but I have a lot of projects so I am learning what I can here. Currently, I am making a meter that allows me to take RF interference and listen to it as sound. I need to build a mixer for this though.
My transmitter operates from very low frequencies(sub 100Hz) to 500KHz, and I will not be transmitting a modulated signal. I can transmit in almost any waveform, but will probably use sine the most. I will be creating the audio via the mixer by clipping off the top of the signal and turning it into audio. So I transmit at 5KHz for example and then I set my local oscillator on the receiver to either 5.5KHz or 4.5KHz to create a 500Hz tone as the difference product of the mixer. Then I will be able to hear frequency, phase, and amplitude variations as audio if they are near the target frequency. I will also need to make an adjustable low pass filter of some kind to kill anything above the output band. The audio ranges would probably go to a headphone amp daughterboard after that.
So my big problem here is that I do not know electronics well enough to pick the values for this mixer. I can't find an existing product that works in these frequencies. I have been leaning toward a diode ring as a double balanced mixer, but I have also been looking at Gilbert Cells. I'm trying to keep this as basic as possible given my inexperience, but I'm on a mission here and really need to put something together. Can anyone give me some guidance on selecting specific diodes for this? Will I need to amplify the raw antenna signal before mixing?
Also, does anyone know of a diode mixer circuit that doesn't use transformers? I am trying to keep inductors out of this design as much as possible. What is my best design for this?
I have KiCad and sort of know how to use it. Does anyone know if the Spice simulator it has can properly simulate a signal mixer? I'm a little lost on how to do something that advanced with it. I know this is a lot of odd questions sorry! Thanks in advance for any help!
