a tldr:I was wondering if its possible to use a current sensor, a comparator and relay to replace (in functionality) the 240VAC mechanical circuit breakers currently in use. Would they be as reliable and safe as the mechanical ones ?
the backstory:So, a friend of mine wanted a way to control the circuitry at his home via smart phone, following the "smart house" hype I'd assume. He came to ask me about how to go about doing that. Since 240VAC isn't my area of expertise I was very hesitant to give him a clear answer.
I mainly work with digital circuits for micro-controllers, specifically arduino. so im very wary and skeptical when it comes to voltages as high as 240V. I do understand the theory when it comes to power electronics, but i'm missing the practical experience.
I thought about it for some time and I thought "If you can switch on/off the circuit breaker, than that's basically controlling the circuitry of every room in the house", not sure if that's a good idea though but that's where I am now in the thought process.
The reason I picked the circuit breakers is because they're all gathered in the distribution box, making it easier to install for the entire house.
And the reason for "electronic" from "mechanical" is that way it can be controlled by a micro-controller.
Any insight on the subject is appreciated. Thank you
