Author Topic: using CRT electron beam for something other then display?  (Read 28010 times)
Online coppercone2Topic starter
« on: February 25, 2024, 07:29:24 am »
So the CRT allows you to control a electron beam on a grid.
Rather then exciting phosphor, can you use it for some other purpose? there are many uses of electron beams.
https://en.wikipedia.org/wiki/Electron-beam_technology
Assuming you can highly modify a CRT
I imagined like sawing open a television with a diamond saw so you can put the front on a hinge with some kinda vacuum gasket and put stuff in there
also it would be good part of men in black or something if they find some aliens misusing TV's like that. they don't use that to watch the game, slick
« Last Edit: February 25, 2024, 07:43:41 am by coppercone2 »
Offline wasedadoc
Re: using CRT electron beam for something other then display?
« Reply #1 on: February 25, 2024, 08:13:22 am »
Before solid state image sensors were developed, for about 50 years all TV cameras used tubes employing electron beam scanning. Search using terms such as "image orthicon", "vidicon" and "Plumbicon".
Offline Andy Chee
« Reply #2 on: February 25, 2024, 08:35:20 am »
You can use it to make some interesting youtube videos:
Offline JustMeHere
« Reply #3 on: February 25, 2024, 08:39:06 am »
Why do I feel like I'm on the Black Mesa Compound tram?
Offline tggzzz
« Reply #5 on: February 25, 2024, 09:46:31 am »
i mean can you make a manufacturing machine out of it some how. the page I listed has alot of process, as interesting as those are,
Like milling etc
I am guessing the focus is too poor to do small things, and power is well too low for welding (is it? its in a vacuum after all). But something like coatings, chemistry, materials prep (some kind of macro structures that require more focus then essentially putting them over a vat of boiling metal in a vacuum). Vacuum soldering with electron beam?
« Last Edit: February 25, 2024, 09:50:08 am by coppercone2 »
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: February 25, 2024, 09:52:03 am »
a-d converter : http://electricstuff.co.uk/glassadc.html
Another one was for TV pattern generators - similar to a camera tube but with a fixed pattern target
Day Job: Mostly LEDs
Online tooki
« Reply #7 on: February 25, 2024, 12:17:07 pm »
Offline jonpaul
« Reply #8 on: February 25, 2024, 12:53:01 pm »
Numeric 0..9 readout, Nimo, 1960s
ENIAC 1949..1953 data storage
TRW 1960s streak camera image converter
j
Jean-Paul  the Internet Dinosaur
Offline wasedadoc
« Reply #9 on: February 25, 2024, 04:30:01 pm »
Also standard for decades was the "flying spot scanner" for televising  film and slides.  A full brightness raster on the CRT faceplate, focussed onto the celluloid and then through optical colour filters to photomultipliers providing the video RGB signals.
https://en.wikipedia.org/wiki/Flying-spot_scanner
Online tooki
« Reply #10 on: February 25, 2024, 04:32:00 pm »
Those both work by exciting phosphor, which is expressly NOT what the OP wants to learn about.
Offline Alex Eisenhut
  • Place text here.
« Reply #11 on: February 25, 2024, 04:42:35 pm »
https://en.wikipedia.org/wiki/IBM_1360
"Data was written to the chips using an electron gun, similar to the operation of a television tube."
Offline tggzzz
« Reply #12 on: February 25, 2024, 04:49:44 pm »
The Eidophor and Talaria:
http://www.earlytelevision.org/Yanczer/eidophor.html
I forgot eidophors.
I saw one once in ~1985, at London Zoo. There was a conference about this newfangled thing, object oriented programming. One of the talks showed building a GUI plus application (in LISP, of course) on the fly, the first time I had seen anything like that.
The projector was an black and white eidophor, which I expect was adequate with "natural" images. But with rectangular bars and text it was, um, suboptimal. The oil film couldn't cope with sharp edges blocks, and any change anywhere in the picture caused the rest to wobble.
But nobody cared; the content was eye-opening.
Online tooki
« Reply #13 on: February 25, 2024, 04:59:31 pm »
Nice! I wonder if there exist any working Eidophor units anywhere in the world. I’d love to see that crazy piece of engineering!
(I finally got to see a Linotype this summer, after wanting to see one for decades. Then this summer I saw two different ones, one day apart, one of them working!)
Offline MarkT
« Reply #14 on: February 25, 2024, 06:00:02 pm »
BANG!!!
No, don't do that.  Watch this video on reconditioning TV tubes first:
Offline tggzzz
« Reply #15 on: February 25, 2024, 06:09:53 pm »
BANG!!!
Yeah. Don't cut the ugly bit off a Tek 465 CRT.
Often there is an easily snappable nipple inside the pins at the end of the tune.
https://entertaininghacks.wordpress.com/2016/03/09/rescuing-a-broken-tektronix-465-crt/
Offline Gyro
« Reply #16 on: February 25, 2024, 06:54:47 pm »
The other problem is that the emissive coating on the cathode will be destroyed as soon as it comes into contact with air. In manufacture, it is coated with chemical salts and then the final forming is done under vacuum.
Best Regards, Chris
Offline p.larner
« Reply #17 on: February 25, 2024, 07:30:57 pm »
i thought electron beams needed a vacume to travel,so whats going on in the linked vid?
Offline TimFox
« Reply #18 on: February 25, 2024, 08:29:24 pm »
Electron beams travel better In vacuum.
High-energy beams can be useful in air, so long as the window between the source (in a vacuum chamber) and air is thin enough, or a “differentially pumped” exit aperture is used.
In air, the range for an electron, depending on how you define it, is roughly 2 mm at 1 keV, but about 10 m at 1 MeV.
Thus, energetic electrons from an electron accelerator can be used in radiation therapy, avoiding the low efficiency of Bremsstrahlung to produce x-ray photons (which have longer range in matter than massive electrons or ions).
Offline SiliconWizard
« Reply #19 on: February 25, 2024, 09:06:38 pm »
Can we use a CRT as a giant triode?
Offline Gyro
« Reply #20 on: February 25, 2024, 09:12:38 pm »
Well a large screen one would take 25kV or so, but the cathode, and possible cathode current, is tiny. So not giant, no.
Best Regards, Chris
« Reply #21 on: February 25, 2024, 09:25:03 pm »
I would imagine so long you keep it dry its OK? Guess you would need a dry box to load this up.
how strong are those electrons anyway. can it say weld foil possibly? say 0.001. In open air for a tig beam that is something like an amp, supposedly. A TV beam is something like 100uA. 0.0001 vs 1. But how much less do you need in a vacuum on thin material. It says EBW uses 50mA to 1A typically.
So you need 500x overload on the beam gun. I guess that process is out.
« Last Edit: February 25, 2024, 09:28:32 pm by coppercone2 »
Offline cosmicray
« Reply #22 on: February 25, 2024, 09:27:38 pm »
Back in the dark ages, of 1987-1988, I saw a piece of kit, that was apparently a very custom build. It read 9-track computer tapes, with print page images, then used a CRT beam (of some type) to directly imprint 35mm film. The film was then developed, and used to make printing plates. The plates were put on offset presses to print books containing television ratings, which were then express shipped out to advertising agencies and networks. It was a very refined system, with lots of disparate parts. The internet has likely demolished it.
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
  • Place text here.
« Reply #23 on: February 25, 2024, 09:30:13 pm »
Sounds like a kind of photo typesetter.
https://en.wikipedia.org/wiki/Phototypesetting
Offline TimFox
« Reply #24 on: February 25, 2024, 09:35:04 pm »
Going back to the 1970s, Celco made relatively small screen CRTs with superb focusing that could resolve 10,000 lines.  They were used either with high-end lenses or optical contact to expose 35 mm or 2.25 inch film.
Celco still exists, mainly working with cinema applications.
