I'm sure many of you heard of the $3000 bounty that was collected by a fellow who managed to get the Kinect addon for the Xbox 360 to work natively in Linux just three hours after it was released.
A little over a week later some folks managed to get it working on a robot.
There's a bunch of other things that it has been used for too. One video put up by the same guy who made the open source drivers shows him using the kinect to control the a laser driver to display an image on a box that he holds up in front of it.
To me it seems like microsoft will sell a lot of units to people who want to use it for creative purposes. I don't own any consoles, but it seems like it would be a great utility for people who need a cheap and relatively simple sensor for their machine. It combines an accelerometer, depth sensing camera, and an RGB camera all in one. The thing can even angle itself up or down. A simple solution for people who either aren't able to use, or afford things like LIDAR sensors. The big issue I see with this device, is that it needs a somewhat large area to work, hence why you need a full size living room to use it for playing games. I'm not sure if range would be as big of an issue if you're just using it for detecting simple boundaries though. I haven't worked with it at all.
What do you guys think?
