Author Topic: datasheet for 4GLM-12232-2-LD 122x32 LCD display  (Read 1728 times)
Offline ledtester
« on: January 24, 2016, 05:37:30 am »
Hi all,
I'm looking for a downloadable copy of the 4GLM-12232-2-LD 122x32 LCD display datasheet.
It's an ancient part, but I'd like to have it around in case I need it.
I found links to it at:
- http://www.2shared.com/document/XkJaQMzQ/4GLM_12232-2.html
- https://www.scribd.com/doc/6564456/4GLM-12232-5LDE-5V
but they either don't work or require payment.
I could just take screenshots of the scribd link, but having a PDF would be nice.
Does anyone have the datasheet or one for a similar working part?
Thanks,
ER
Offline Skimask
Re: datasheet for 4GLM-12232-2-LD 122x32 LCD display
« Reply #1 on: January 24, 2016, 05:51:13 am »
One of these might work.  Pretty much all the same.  Depends on the driver IC.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline amyk
« Reply #2 on: January 24, 2016, 04:26:05 pm »
I was able to download the first one, just click the Download button... and I've attached that file here.
Offline ledtester
« Reply #3 on: January 24, 2016, 07:11:48 pm »
Thanks for the help - much appreciated!
