Author Topic: Which micro controller would be suitable? (camera/wifi/PIR sensor)  (Read 1839 times)
Offline mastermawTopic starter
Hello all, I need some recommendations for microcontrollers. The project is a small security device, running on a single AA or button cell.
A PIR sensor detects motion, which latches a relay, turning on a camera and WiFi.
The camera takes a picture, saves it to storage and then emails the picture via SMTP to a preset recipient and deletes the image.
Of course to conserve power the cam and wifi are always turned off unless motion is detected. Clearly a small button cell wouldn't last long powering wifi!
So, I need a microcontroller with very low consumption, at least 1mb of onboard storage, a CPU capable of processing an image and firing off an email within 10 seconds, and reasonably simple connectivity with a WiFi chip and camera.
Ideally, all the components should ultimately be available for under $40 - but for my project, it's not an issue. The components should also ideally fit in a 5cm2 box - but for a prototype, size isn't a problem.
I know similar security devices exist but this is a fun project for me. The crucial thing here is that the device can run on a small battery - AA or perhaps a button cell. In which case, might it be sensible to have the PIR+controller separate to the cam/wifi controller?
Does a suitable microcontroller spring to mind? I've played with arduinos but find the various shields a little clumsy and thought better options might exist. There are so many Atmel and TI options out there, it's a bit bewildering.
Any advice much appreciated!
Thanks.
Maw.
Offline nctnico
Re: Which micro controller would be suitable? (camera/wifi/PIR sensor)
« Reply #1 on: April 26, 2013, 01:31:18 pm »
If you are going for low power then the MSP430 from TI is the best choice. The MSP430 has been specifically designed for low power from the start.
Online eliocor
    • rhodiatoce
« Reply #2 on: April 26, 2013, 02:30:17 pm »
are you sure regarding power requirements of your PIR sensor?
To my knowledge they typically require from 0.5mA to 2-3mA (some rarer devices require only 100uA).
I'm not so sure how long your battery will last (sensor must always be on)...
