Author Topic: using the DRV8816 2x 1/2 bridge as high or low side switch  (Read 384 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: January 29, 2020, 11:29:45 am »
i am looking at the following: http://www.ti.com/lit/ds/symlink/drv8816.pdf
If I pul the input to the side I want to operate and instead PWM the enable pin would this effectively allow me to select and control the highside or low side only?
