Yeah, TTL is all NPN so there's not a lot of funny business going on. (Maybe in the more analoggy types like timers?)
Actually, how do inputs pull up to the ~3V they do? Or am I misremembering the OCV? It should be 1.2V from the diagram, with additional current sunk at higher voltages due to inverted operation. (Mainly, that input arrangement works more like a pair of diodes; I suppose coupling them together performs a bit better than ye olde DTL, but it's basically the same function.)
Reverse mode was used quite extensively in the olden days, lateral PNP for example.
Maybe that's arguable; can you really invert a symmetrical transistor?
Personally, I've used the mode for low leakage or saturation, or higher voltage range, like in these examples:
The middle line comes from a current-limited signal, and its positive value is clamped close to the top voltage. It should work alright the other way around, but I found E-B leakage was objectionable (compared to a 1-10k ohm source).
This discrete synchronous rectifier works, a little slowly (100s ns), but does what it says on the tin. Max rating is Vceo of the leftmost transistor (which should be matched to the other inverted type, of course; I suppose mismatched Vbc's might be interesting to play with, however). Response time manifests as forward and reverse recovery (with forward recovery being limited by the FET's body diode, which, I've never seen noticeable forward recovery in MOSFETs, curiously enough; thus, the apparent forward recovery transient is limited to the body drop, until the channel begins conduction), and I think the feed-forward path makes reverse recovery depend on dV/dt (and via Ls, dI/dt in turn), analogous to the case for real diodes.
