Author Topic: Using triac as AC power line switch  (Read 926 times)
Offline XaviPachecoTopic starter
  • Country: do
« on: June 17, 2018, 05:53:14 pm »
I attach a circuit where I pretend to control the AC input to a bridge rectifier. I usually see that triacs are used in AC switching and phase control applications such as motor speed and temperature modulation controls, lighting controls, and static switching relays. In this case I just want to control the moment when the bridge is going to be fed. The Triac that I will use is 1-3 quadrant triac. I've seen 4 quadrant triacs, but not so common.  Do you think that it could work the way I have arranged the circuit?
Offline james_s
Re: Using triac as AC power line switch
« Reply #1 on: June 17, 2018, 06:00:12 pm »
It looks reasonable. It's certainly not unheard of to use a triac based SSR to control the power of something.
The following users thanked this post: XaviPacheco
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #2 on: June 17, 2018, 06:04:25 pm »
You know... you have just invented a SSR.  ;D
//EDIT: And btw, you circuit lacks inrush current limiting. Add at least a suitable NTC in series with the input.
« Last Edit: June 17, 2018, 06:10:37 pm by Yansi »
