I’m using the RS Components linear solenoid, part no. 177-0114 (datasheet attached and RS product page here:
https://uk.rs-online.com/web/p/linear-solenoids/1770114 ). The available documentation is sparse, and the specification table is confusing: it appears to cover multiple part numbers, but this is not stated, making it unclear which parameters apply to this specific device.
The solenoid is marked as 24 V rated (datasheet and part marking). However, measured coil resistance is 194 Ω, which does not correspond to any value in the table. The closest listed resistances are 69 Ω and 275 Ω, far outside reasonable tolerance, so it’s unclear how to interpret the electrical data or how to relate it to the force vs. current graph.
I drive the solenoid with a DRV103 peak-and-hold driver (datasheet attached). During hold, the driver operates in PWM mode at 25 kHz, 30% duty cycle, per the attached schematic. The pull (peak) duration is currently set to 100 ms.
I’d appreciate any guidance on the following:
1) Safe operating limits – How to determine safe hold current (thermal limits) given the unclear datasheet?
2) Force control – How the PWM duty cycle (i.e. average current value) should be selected to achieve a specific pull/holding force with reference to the graph?
3) Pull time - is 100ms enough?
Any practical advice on electrical/thermal characterisation methods for this solenoid would be appreciated.
Thanks.
