I checked your capture with a type A display, and it seems to be fine. The timings are not the same as when the data comes from the car, but for testing purposes it is fine.
If you haven't modified any file in the package (except config.h) it should be fine. I tested with these settings:
#pragma once
#ifndef _Config_h
#define _Config_h
// if defined messages are sent on bluetooth connection, otherwise standard serial is used
//#define USE_BLUETOOTH_SERIAL
// if defined then the ignition signal is used from the VAN bus otherwise the ignition is considered as always on
#define USE_IGNITION_SIGNAL_FROM_VAN_BUS
// if defined the AC status is queried with a diagnostic message (only works with rev 1.4)
//#define QUERY_AC_STATUS
#define TASK_WATCHDOG_TIMEOUT 7
#define FUEL_TANK_CAPACITY_IN_LITERS 60
// 11: HW revision v1.1
// 14: HW revision v1.4
#define HW_VERSION 14
// 1: original layout
// 2: my layout
#define DISPLAY_MODE 1
//#define USE_VIN_AUTO_MATCHING
#ifdef USE_VIN_AUTO_MATCHING
uint8_t Vin[17] = { 0 };
#else
// Fake V2C sends this VIN:
uint8_t Vin[17] = { 'L', 'D', 'C', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8' };
// Original V2C sends this VIN:
//uint8_t Vin[17] = { 'L', 'D', 'C', '9', '4', '3', 'X', '4', '7', 'D', '1', '5', '6', '6', '7', '7', '2' };
#endif
#endif
