Author Topic: VAN bus interfacing (to read car speed and engine RPM Peugeot 206 1.4 HDI 2002)  (Read 94918 times)
Offline morcibacsi
  • Country: hu
Hmm.. interesting. Unfortunately I haven't tested with that display type nor I have one. Can you post a picture about the back of the display where it has the type number on that sticker? I'll try to find one nearby to test with. I'll put up a new version in a few days so you can disable the air conditioning statuses.
EDIT: I have added an option to disable A/C status query from config.h: Just comment the define like so:
// if defined the AC status is queried with a diagnostic message (only works with rev 1.4)
//#define QUERY_AC_STATUS
Also please upload a short VAN bus capture while the problem occures. Just like you did in the video, open the door 3-4 times and capture the packets in the meanwhile. You can do that either in standard serial mode, or in bluetooth serial mode with this app on Android: https://play.google.com/store/apps/details?id=de.kai_morich.serial_bluetooth_terminal&hl=en
« Last Edit: March 19, 2020, 06:56:47 am by morcibacsi »
Offline reggaester
hi,
someone has peeled off the sticker with the number but it is exactly the same as in this picture:
https://d.allegroimg.com/original/0377b5/ec3337ad4d539604580bb53e594d
I don't know if it's important but this emf is from peugeot 207
21:59:30.322 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.322 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:30.362 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.362 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.402 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:30.402 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.442 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.442 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.482 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:30.482 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:30.482 -> 0E 5E 4C 20 1E 8A 50
21:59:30.522 -> 0E 4D 4F 39 2A
21:59:30.522 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.522 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:30.557 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.557 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.592 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:30.592 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.633 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.633 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:30.672 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.672 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:30.712 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.712 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:30.752 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.752 -> 0E 9C 4C 00 80 D4 E2
21:59:30.752 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.792 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:30.792 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.827 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.872 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.872 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:30.907 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.907 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:30.952 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:30.952 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:30.952 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:30.992 -> 0E 5E 4C 20 1E 8A 50
21:59:30.992 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.032 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:31.032 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.032 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:31.072 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.072 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:31.107 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.107 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:31.152 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.152 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:31.152 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.192 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.232 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:31.232 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.232 -> 0E 9C 4C 00 80 D4 E2
21:59:31.273 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.273 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:31.307 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.307 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:31.352 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.352 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.392 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.432 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:31.432 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.472 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.472 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:31.472 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:31.472 -> 0E 5E 4C 20 1E 8A 50
21:59:31.512 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.512 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.512 -> 0E 4D 4F 39 2A
21:59:31.552 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:31.552 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.592 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.633 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.633 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:31.633 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:31.672 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.672 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:31.712 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.712 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.712 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:31.752 -> 0E 9C 4C 00 80 D4 E2
21:59:31.752 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.792 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.832 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.832 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:31.872 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.872 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:31.912 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:31.912 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.912 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:31.952 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:31.952 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:31.992 -> 0E 5E 4C 20 1E 8A 50
21:59:31.992 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.032 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.032 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:32.032 -> 0E 8C 4C 12 20 7A AC
21:59:32.032 -> 0E 56 4E 81 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 81 E3 1E
21:59:32.072 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:32.072 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.072 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:32.112 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.112 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.112 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:32.152 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:32.152 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.192 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.192 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.232 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:32.232 -> 0E 9C 4C 00 80 D4 E2
21:59:32.272 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.272 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:32.272 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.307 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.307 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:32.352 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.392 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.392 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.427 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:32.472 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.472 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:32.472 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:32.472 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.512 -> 0E 5E 4C 20 1E 8A 50
21:59:32.512 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.512 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:32.512 -> 0E 4D 4F 39 2A
21:59:32.552 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.592 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.672 -> 0E 56 4E 85 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 85 29 9C
21:59:32.672 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.672 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:32.672 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:32.712 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.712 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:32.712 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.752 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:32.752 -> 0E 9C 4C 00 80 D4 E2
21:59:32.752 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.792 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.792 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.902 -> 0E 56 4E 83 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 09 C2
21:59:32.902 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:32.902 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.942 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:32.942 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:32.942 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.942 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:32.982 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:32.982 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:32.982 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.022 -> 0E 5E 4C 20 1E 8A 50
21:59:33.022 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.062 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:33.062 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.062 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:33.102 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.102 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.102 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:33.142 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:33.142 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.177 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.222 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.262 -> 0E 9C 4C 00 80 D4 E2
21:59:33.262 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:33.262 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.342 -> 0E 56 4E 84 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 84 5C F2
21:59:33.342 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.377 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:33.377 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.377 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:33.422 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.422 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.457 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:33.457 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.457 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:33.497 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.497 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:33.497 -> 0E 5E 4C 20 1E 8A 50
21:59:33.497 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.542 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:33.542 -> 0E 4D 4F 39 2A
21:59:33.542 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.577 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.612 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.652 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:33.652 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.652 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:33.692 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.692 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:33.772 -> 0E 56 4E 86 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 86 B6 2E
21:59:33.772 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.772 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:33.812 -> 0E 9C 4C 00 80 D4 E2
21:59:33.812 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.812 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.847 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.847 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.892 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:33.892 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:33.892 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.932 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:33.932 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:33.972 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:33.972 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:34.012 -> 0E 5E 4C 20 1E 8A 50
21:59:34.012 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.052 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:34.052 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.092 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.092 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:34.092 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:34.127 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:34.197 -> 0E 56 4E 81 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 81 E3 1E
21:59:34.197 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:34.242 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.242 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.278 -> 0E 9C 4C 00 80 D4 E2
21:59:34.278 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.278 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:34.278 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:34.322 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.322 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:34.357 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.357 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.392 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.432 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.472 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.472 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:34.472 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:34.472 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:34.512 -> 0E 8C 4C 12 20 7A AC
21:59:34.512 -> 0E 56 4E 81 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 81 DE 24
21:59:34.512 -> 0E 5E 4C 20 1E 8A 50
21:59:34.512 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.552 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:34.552 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.552 -> 0E 4D 4F 39 2A
21:59:34.552 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.592 -> 0E 56 4E 82 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 82 41 96
21:59:34.592 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.632 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.632 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:34.672 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.672 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:34.712 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:34.712 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.712 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:34.712 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.747 -> 0E 9C 4C 00 80 D4 E2
21:59:34.747 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.797 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.832 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.872 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.872 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:34.872 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:34.912 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.912 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:34.952 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:34.952 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:34.952 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:34.992 -> 0E 5E 4C 20 1E 8A 50
21:59:34.992 -> 0E 5E 4F DD 78
21:59:34.992 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.032 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.032 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:35.072 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.072 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:35.072 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:35.112 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.112 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.112 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:35.152 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:35.152 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.192 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.232 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.232 -> 0E 9C 4C 00 80 D4 E2
21:59:35.272 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.272 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:35.272 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:35.312 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.312 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.312 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:35.352 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.392 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.432 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.432 -> 0E 56 4E 86 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 86 8B 14
21:59:35.472 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.472 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:35.472 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:35.472 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:35.512 -> 0E 5E 4C 20 1E 8A 50
21:59:35.512 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.512 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.512 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:35.562 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.562 -> 0E 4D 4F 39 2A
21:59:35.597 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.597 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.632 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:35.672 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.672 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:35.712 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:35.712 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.712 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.712 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:35.752 -> 0E 9C 4C 00 80 D4 E2
21:59:35.752 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.792 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.792 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.872 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.872 -> 0E 56 4E 80 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 80 AB 4A
21:59:35.872 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:35.912 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.912 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:35.912 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.912 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:35.952 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:35.952 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:35.992 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:35.992 -> 0E 5E 4C 20 1E 8A 50
21:59:36.032 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.032 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:36.072 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.072 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:36.072 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.112 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:36.112 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.112 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:36.152 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:36.152 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.192 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.192 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.272 -> 0E 9C 4C 00 80 D4 E2
21:59:36.272 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.272 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:36.272 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.312 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.312 -> 0E 56 4E 82 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 82 41 96
21:59:36.312 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:36.347 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:36.347 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.392 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.392 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.472 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.472 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:36.472 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.472 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:36.512 -> 0E 5E 4C 20 1E 8A 50
21:59:36.512 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.512 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:36.512 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:36.552 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.552 -> 0E 4D 4F 39 2A
21:59:36.592 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.592 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.632 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:36.672 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.672 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.672 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:36.707 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.707 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:36.752 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:36.752 -> 0E 56 4E 84 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 84 61 C8
21:59:36.752 -> 0E 9C 4C 00 80 D4 E2
21:59:36.752 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.752 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.792 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.872 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.872 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.872 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:36.912 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.912 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:36.912 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:36.952 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:36.952 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:36.992 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:36.992 -> 0E 5E 4C 20 1E 8A 50
21:59:36.992 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.032 -> 0E 8C 4C 12 20 7A AC
21:59:37.107 -> 0E 56 4E 83 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 09 C2
21:59:37.107 -> E (8410) rmt: RMT RX BUFFER FULL
21:59:37.107 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:37.152 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.152 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.152 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:37.152 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:37.192 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:37.192 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.192 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.272 -> 0E 56 4E 85 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 85 29 9C
21:59:37.272 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.312 -> 0E 9C 4C 00 80 D4 E2
21:59:37.312 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.312 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.312 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:37.352 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.352 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:37.352 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:37.352 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.392 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.432 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.472 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.472 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:37.472 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:37.507 -> 0E 5E 4C 20 1E 8A 50
21:59:37.507 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.507 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:37.542 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:37.542 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.542 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.577 -> 0E 4D 4F 39 2A
21:59:37.622 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.622 -> 0E 5E 4F DD 78
21:59:37.622 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.662 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:37.662 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.662 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:37.697 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.742 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:37.742 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:37.742 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.742 -> 0E 9C 4C 00 80 D4 E2
21:59:37.777 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.822 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.822 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.862 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.862 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:37.897 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.942 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:37.942 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:37.942 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:37.942 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:37.980 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:37.980 -> 0E 5E 4C 20 1E 8A 50
21:59:38.022 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.022 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.022 -> 0E 5E 4F DD 78
21:59:38.062 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:38.062 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.062 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:38.097 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.142 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:38.142 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.142 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:38.142 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:38.142 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.222 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.222 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.262 -> 0E 9C 4C 00 80 D4 E2
21:59:38.262 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.262 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:38.302 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.302 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.342 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:38.342 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:38.342 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.422 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.422 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.457 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.457 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:38.497 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:38.572 -> 0E 56 4E 83 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 09 C2
21:59:38.572 -> 0E 5E 4C 20 1E 8A 50
21:59:38.572 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.572 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.612 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:38.612 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:38.612 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.612 -> 0E 4D 4F 39 2A
21:59:38.652 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.652 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.652 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:38.692 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:38.692 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.732 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.732 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:38.732 -> 0E 9C 4C 00 80 D4 E2
21:59:38.772 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:38.772 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.812 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.812 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.862 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.862 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:38.902 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:38.902 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:38.977 -> 0E 56 4E 85 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 85 29 9C
21:59:39.022 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:39.022 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.022 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:39.022 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:39.022 -> 0E 5E 4C 20 1E 8A 50
21:59:39.062 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.062 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.062 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:39.102 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:39.102 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.102 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.102 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:39.142 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:39.142 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.177 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:39.222 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.222 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.222 -> 0E 8C 4C 12 20 7A AC
21:59:39.262 -> 0E 56 4E 85 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 85 14 A6
21:59:39.262 -> 0E 9C 4C 00 80 D4 E2
21:59:39.262 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.262 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:39.297 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.297 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.342 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:39.342 -> 0E 56 4E 80 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 80 AB 4A
21:59:39.342 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.381 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:39.381 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.422 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.462 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.462 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:39.462 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:39.497 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.497 -> 0E 5E 4C 20 1E 8A 50
21:59:39.497 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.542 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:39.542 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.577 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:39.577 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.622 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.622 -> 0E 4D 4F 39 2A
21:59:39.662 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:39.662 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.697 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:39.697 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.697 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.742 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:39.742 -> 0E 9C 4C 00 80 D4 E2
21:59:39.742 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.782 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:39.782 -> 0E 56 4E 81 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 82 FF 6A
21:59:39.782 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.822 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.857 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.897 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:39.897 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:39.897 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.932 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:39.972 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:39.972 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:39.972 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:39.972 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.012 -> 0E 5E 4C 20 1E 8A 50
21:59:40.012 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.052 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:40.052 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.092 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:40.092 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.132 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.132 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:40.132 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:40.172 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.172 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.172 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:40.212 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.212 -> 0E 56 4E 83 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 34 F8
21:59:40.252 -> 0E 9C 4C 00 80 D4 E2
21:59:40.252 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.292 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.292 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:40.292 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.327 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:40.362 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.362 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.362 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:40.397 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.442 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.482 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:40.482 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.482 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:40.482 -> 0E 5E 4C 20 1E 8A 50
21:59:40.522 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.522 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:40.562 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.562 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.602 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:40.602 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.602 -> 0E 4D 4F 39 2A
21:59:40.642 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:40.642 -> 0E 56 4E 85 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 85 14 A6
21:59:40.682 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.682 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.682 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:40.722 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.722 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:40.762 -> 0E 9C 4C 00 80 D4 E2
21:59:40.762 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.762 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.802 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:40.802 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.842 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.882 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:40.882 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:40.922 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:40.922 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:40.922 -> 0E 8C 4C 12 20 7A AC
21:59:41.002 -> 0E 56 4E 84 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 84 5C F2
21:59:41.042 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.042 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.042 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:41.042 -> 0E 5E 4C 20 1E 8A 50
21:59:41.082 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:41.082 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.082 -> E (12373) rmt: RMT RX BUFFER FULL
21:59:41.082 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:41.082 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.122 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.122 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:41.122 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:41.162 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:41.162 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.162 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.202 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:41.202 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.242 -> 0E 9C 4C 00 80 D4 E2
21:59:41.242 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.282 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.282 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:41.322 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.322 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:41.362 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.362 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.402 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:41.402 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.442 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.442 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.477 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:41.477 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:41.477 -> 0E 5E 4C 20 1E 8A 50
21:59:41.522 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.522 -> 0E 5E 4F DD 78
21:59:41.522 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:41.562 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.562 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.602 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.602 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:41.642 -> 0E 4D 4F 39 2A
21:59:41.642 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.642 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:41.642 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.685 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:41.685 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.722 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:41.762 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.762 -> 0E 9C 4C 00 80 D4 E2
21:59:41.762 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.802 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.842 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:41.842 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:41.842 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.877 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:41.912 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:41.912 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:41.912 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.032 -> 0E 56 4E 83 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 09 C2
21:59:42.032 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.032 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:42.072 -> 0E 5E 4C 20 1E 8A 50
21:59:42.072 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.072 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:42.072 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.107 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:42.107 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.107 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:42.142 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:42.142 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.142 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:42.182 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.222 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.222 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:42.222 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.262 -> 0E 9C 4C 00 80 D4 E2
21:59:42.262 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.262 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:42.302 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.302 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:42.342 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.342 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.462 -> 0E 56 4E 85 00 00 00 00 00 00 40 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 85 29 9C
21:59:42.462 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.462 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.462 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:42.497 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.497 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:42.497 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:42.542 -> 0E 5E 4C 20 1E 8A 50
21:59:42.542 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.542 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.542 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:42.622 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.622 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.622 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:42.622 -> 0E 8C 4C 12 20 7A AC
21:59:42.662 -> 0E 56 4E 83 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 34 F8
21:59:42.662 -> 0E 4D 4F 39 2A
21:59:42.662 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:42.662 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.702 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:42.702 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.702 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.742 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:42.742 -> 0E 9C 4C 00 80 D4 E2
21:59:42.742 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.822 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.822 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.822 -> 0E 56 4E 86 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 86 8B 14
21:59:42.822 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:42.862 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.862 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:42.902 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:42.902 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.942 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:42.942 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:42.982 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:42.982 -> 0E 5E 4C 20 1E 8A 50
21:59:43.022 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.022 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.022 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:43.057 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:43.057 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.102 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:43.102 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.102 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.102 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:43.142 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:43.142 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.182 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.222 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.222 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:43.262 -> 0E 9C 4C 00 80 D4 E2
21:59:43.262 -> 0E 56 4E 81 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 81 DE 24
21:59:43.262 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.302 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:43.302 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.302 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.302 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:43.342 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.382 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.422 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.422 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:43.462 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.462 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:43.462 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:43.497 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.497 -> 0E 5E 4C 20 1E 8A 50
21:59:43.497 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.542 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:43.542 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.582 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.622 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.662 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:43.662 -> 0E 4D 4F 39 2A
21:59:43.662 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.697 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:43.697 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.697 -> 0E 56 4E 83 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 83 34 F8
21:59:43.697 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.742 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:43.742 -> 0E 9C 4C 00 80 D4 E2
21:59:43.742 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.782 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.822 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.862 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:43.862 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.862 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.902 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:43.902 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.902 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:43.942 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:43.977 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:43.977 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:43.977 -> 0E 5E 4C 20 1E 8A 50
21:59:44.022 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.062 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:44.062 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:44.062 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.062 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.102 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:44.102 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.102 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:44.142 -> 0E 56 4E 84 00 00 00 00 00 00 00 00 00 18 00 00 27 00 00 FF FF 00 00 FF FF FF FF 01 4A 84 61 C8
21:59:44.142 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:44.142 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.177 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.222 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.262 -> 0E 9C 4C 00 80 D4 E2
21:59:44.262 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.262 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:44.262 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.302 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:44.302 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.302 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:44.342 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.377 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.422 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.462 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.462 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.462 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:44.502 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:44.502 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:44.502 -> 0E 5E 4C 20 1E 8A 50
21:59:44.502 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.542 -> 0E 4D C8 80 00 1B 02 61 FF FF 9B EA
21:59:44.542 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.577 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.577 -> 0E 5E 4F DD 78
21:59:44.612 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.647 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:44.647 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.689 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.689 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:44.689 -> 0E 4D 4F 39 2A
21:59:44.689 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:44.727 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.727 -> 0E 4D CC 80 00 1B 02 60 FF FF A9 8E
21:59:44.772 -> 0E 9C 4C 00 80 D4 E2
21:59:44.772 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.772 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.807 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.842 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.842 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.877 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:44.877 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:44.922 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.922 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
21:59:44.957 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:44.957 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:44.957 -> 0E 52 48 08 00 81 00 20 03 00 00 00 FF 00 00 00 00 00 00 C8 A0
21:59:44.997 -> 0E 5E 4C 20 1E 8A 50
21:59:44.997 -> 0E 5E 4F DD 78
21:59:44.997 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.042 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:45.042 -> 0E E2 48 56 46 33 33 43 52 48 52 48 38 33 37 32 31 36 36 34 F4 28
21:59:45.042 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.077 -> 0E 66 4C 00 00 0F 04 FF FF 00 FF FF FF 02 00 C1 48
21:59:45.077 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:45.112 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.112 -> 0E 4D CC 80 00 1B 02 61 FF FF C2 48
21:59:45.152 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:45.152 -> 0E 8A 48 8F 03 4B 28 64 67 66 02 EC
21:59:45.152 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.190 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.232 -> 0E 46 4C 00 05 FF FF 00 E1 B8
21:59:45.232 -> 0E 9C 4C 00 80 D4 E2
21:59:45.272 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.272 -> 0E 4F CC 80 00 01 16 00 00 FF 1F 64 00 FE 00 00 00 DA 2E
21:59:45.307 -> 0E 82 48 00 00 00 00 00 00 00 54 98
21:59:45.307 -> 0E 4D C8 80 00 1B 02 60 FF FF F0 2C
Offline morcibacsi
  • Country: hu
I checked your capture with a type A display, and it seems to be fine. The timings are not the same as when the data comes from the car, but for testing purposes it is fine.
If you haven't modified any file in the package (except config.h) it should be fine. I tested with these settings:
#pragma once
#ifndef _Config_h
    #define _Config_h
// if defined messages are sent on bluetooth connection, otherwise standard serial is used
//#define USE_BLUETOOTH_SERIAL
// if defined then the ignition signal is used from the VAN bus otherwise the ignition is considered as always on
#define USE_IGNITION_SIGNAL_FROM_VAN_BUS
#define TASK_WATCHDOG_TIMEOUT 7
#define FUEL_TANK_CAPACITY_IN_LITERS 60
// 11: HW revision v1.1
// 14: HW revision v1.4
#define HW_VERSION 14
// 1: original layout
// 2: my layout
#define DISPLAY_MODE 1
//#define USE_VIN_AUTO_MATCHING
#ifdef USE_VIN_AUTO_MATCHING
    uint8_t Vin[17] = { 0 };
#else
    // Fake V2C sends this VIN:
    uint8_t Vin[17] = { 'L', 'D', 'C', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8', '8' };
    // Original V2C sends this VIN:
    //uint8_t Vin[17] = { 'L', 'D', 'C', '9', '4', '3', 'X', '4', '7', 'D', '1', '5', '6', '6', '7', '7', '2' };
#endif
#endif
Offline reggaester
the problem was that this display came from 207, yesterday I bought an emf type a display from 307 and the problem was solved :)
what is app do you use on video?? looks interesting
btw when I disconnect the old emf b and I only use the new emf and with the bridge the air conditioning compressor does not want to start, when I connect it back and I use both then it starts. Is that the same in your car? I dealt with it so that I dragged the wires to the glove box and placed it there. In addition, I took out the light bulbs from it so that it does not get hot.
Offline morcibacsi
  • Country: hu
The application is a small test app I've written in C# I can send CAN bus messages with it and I can also replay the VAN bus captures. This way I don't have to be in the car to test things, it helps me troubleshooting a lot.
Regarding your A/C: The VAN bus lines for the A/C is routed through the display so if you remove it then it stops working. A workaround is to create a shortcut between pin 4-5 and 17-18 with a small wire. I put there a 90 degree pin header with a small solder-joint (see attachment).
My next project will be the parking radar support. I need to get a working set, but it is really hard to find one. I am looking for it for months now :( Do you have it on your car?
Offline reggaester
yeah, a/c now work fine :D
unfortunately I do not have parking radar, but I can ask on a fan group 307 on Facebook, maybe someone has it and will sell it to me at a good price :)
thank you again for your great work. what was not possible in pre lift 307 now works very well: D
now I'm starting to look for rd45 and emf c, it's hard to get them at a low cost but sometimes people don't know what they are selling :) if I don't find it, I will order it on the aliexpress, but it also isn't easy becouse those epidemy :( In Hungary also situation is bad?
what do you think about this project? https://medium.com/@alexandreblin/can-bus-reverse-engineering-with-arduino-and-ios-5627f2b1709a
could something like this be used in our 307?
Offline morcibacsi
  • Country: hu
Yeah RD45 is the best, however the RD43 is also fine for listening music from an USB stick. I used one for almost two years. I ordered my RD45 and displays from aliexpress. Sometimes they can be found very cheap.
I know that project I used some information from there in mine. I think it should work with my bridge as most of the CAN messages are the same (however there might be some exceptions as we saw with your display :)). By the way I was planning to build a setup with a larger screen, but it is rather hard to do it with a microcontroller. And I wouldn't like to have something in my car which takes some time to boot. Someone mentioned that a Raspberry Pi with a stripped down linux revision would bootup almost instantly, but I haven't looked at it yet. There are so many projects that could be done, but there is so little time :D
Thanks for your kind words, go spread my project in those forums :D Maybe others find it useful as well.
« Last Edit: March 21, 2020, 10:34:34 am by morcibacsi »
Offline reggaester
Is it possible to receive and send can messages via bluetooth?
Offline morcibacsi
  • Country: hu
I haven't implemented that in my VAN-CAN bridge project. However it is possible to do it. Why do you ask? What would you like to achieve?
Offline reggaester
if it was possible, an android application that would be emulate emf on any display (tablet or phone) without using wires. Is my thinking correct?
Offline morcibacsi
  • Country: hu
It can be done, but maybe it would be better to create a custom protocol between the phone and the microcontroller (as Alexandre did in his project), as there are a LOT of can messages floating around. If the CAN messages would be pumped through the bluetooth connection I am afraid the data won't be real-time. So it would be better to only send the data we want to display.
Offline reggaester
A few days I am getting knowledge about van and can packages. Recently from here http://pinterpeti.hu/psavanbus/PSA-VAN.html
Can you share me your test app? this can be very helpful
Offline morcibacsi
  • Country: hu
I still keep finding new info in the packages :) The test app is not in a shape to be published. Sometimes it hangs sometimes it crashes, but I am working on it. In the meanwhile... parking aid support is coming :) Apparently it is much easier to find a parking radar from a Citroen XSara than from a Peugeot 307...
Offline adv
Hello guys,
still a big step forward in VAN protocol digging with this VAN/CAN bridge Peter  :-+ (I saw your git, wowww it's complex for me).
Today new day of containement, and new stupid idea... Have you ever seen recent car (or motocycle) which activate their RPM and speed gauge to the top a short time and go back to zero when you start the engine ?! It looks sporty. This is my new goal for my 406 coupĂ© (which is not a sportcar obviously) to make give her 10 years less than she is  :-DD
I can test both gauges with the Peugeot diagnostic interface (and Peugeot Planet 2000). The idea is to catch the data / analyse them and send them when the arudino boots (like I do to display "406Coupe" on the screen while the original HU is removed).
I saw you develloped a plugin for selae logic analysers. The thing is that these analysers are too expensive for the usage I will have, do you used a cheap clone ? (if so could you share here or in PM the one you choosed ?)
I saw you also develloped the VAN reader with the ESP32+SN65HVD230. I have both parts in stock, if I understand well it would be okay for my goal (analyse data at the moment I activate gauge test), it would dump data into the Arduino serial terminal right ?
Thanks a lot for help and stay safe man !
« Last Edit: April 22, 2020, 07:49:52 am by adv »
Offline morcibacsi
  • Country: hu
I bought this logic analyser, this is perfectly fine: https://www.aliexpress.com/item/32873970588.html
For reading the VAN bus, you are good to go with the ESP32+SN65HVD230 (or in fact any CAN transceiver is ok, and it is possible to read even with connecting one of the VAN lines directly to the ESP32).
I captured some packets while the diagnostics was connected (on a Peugeot 307), you should check for messages like these:
Speedometer test:
13:46:43.472 -> 0E A7 CC 30 80 20 13 88 2A 54
13:46:43.577 -> 0E AF CE 80 70 80 01 80 27 9C
13:46:43.818 -> 0E A7 CC 30 80 01 A9 38
13:46:43.922 -> 0E AF CE 81 70 80 01 81 C5 1E
Tacho test:
13:47:26.160 -> 0E A7 CC 3E 45 68
13:47:26.263 -> 0E AF CE 82 7E 82 8D F4
13:47:27.680 -> 0E A7 CC 30 81 20 5D C0 5E CA
13:47:27.749 -> 0E AF CE 83 70 81 01 83 74 E6
13:47:27.955 -> 0E A7 CC 30 81 01 DB D4
13:47:28.059 -> 0E AF CE 84 70 81 01 84 E7 1C
Fuel gauge test:
13:47:56.956 -> 0E A7 CC 3E 45 68
13:47:57.059 -> 0E AF CE 81 7E 81 10 F0
13:47:59.106 -> 0E A7 CC 30 83 20 19 26 C4
13:47:59.209 -> 0E AF CE 82 70 83 01 82 41 E8
13:47:59.313 -> 0E A7 CC 30 83 01 3E 0C
13:47:59.414 -> 0E AF CE 83 70 83 01 83 A3 6A
Coolant temperature test:
13:48:40.951 -> 0E A7 CC 3E 45 68
13:48:41.056 -> 0E AF CE 86 7E 86 41 3E
13:48:41.814 -> 0E A7 CC 30 84 20 7E 22 22
13:48:41.918 -> 0E AF CE 87 70 84 01 87 04 44
13:48:42.022 -> 0E A7 CC 30 84 01 7D B2
13:48:42.125 -> 0E AF CE 80 70 84 01 80 97 BE
I haven't decoded them just dumped them for further investigation.
« Last Edit: April 22, 2020, 08:04:52 am by morcibacsi »
Offline adv
Nice to see you're still alive !
OK I'll buy this one, it's cheap and can be used for another purposes. It was a long time I was looking for that.
For decoding well, I'll try to work on that... but I'm really far to your knowledges...  :-X
Have a good day !
The following users thanked this post: morcibacsi
Offline reggaester
hello ;)
I see there is a rep update. Can you describe the changes please?
Offline morcibacsi
  • Country: hu
There were some in the last few days, however most of them were code quality related changes. The ones what is worth mentioning are:
  • I added Parking aid support - now if you have an original parking aid installed the display shows the distance of the obstacle with the small bars (need to be tested in real car)
  • I added a serial command to read the VIN number coded to the head unit via CAN message (this could come in handy when someone does not have access to a car with a CAN BSI, you need to send the letter "n" and the VIN will get printed to the serial monitor)
  • A fellow member rewrote the popup message handling - now it is more user friendly (no repeated messages, and some of the messages could get stuck on the display)
  • The trip computer button should be more responsive (you also need to update the TSS463 library for this)
These can be activated from the config.h file.
Offline reggaester
hi Peter :)
Can you describe new update?
Also can you tell me how reset the trip computer? When I press the trip button for few seconds, the trip computer will no reset but functions is looping.
Offline morcibacsi
  • Country: hu
Finally I resolved a very annoying issue regarding trip computer data flickering. You can see what was the problem here: https://github.com/morcibacsi/PSAVanCanBridge/issues/10. And I completely rewrote the part which is responsible for the messages and door statuses shown on the display. Now it supports type A display, and should work much more like the original display did (regarding how and when the messages are displayed) The trip computer (no)reset is a known issue :( I have a small memo for myself here: https://github.com/morcibacsi/PSAVanCanBridge/issues/9 The original display is responsible for resetting the trip computer. And if we remove it it should be handled by my software. I did a little investigation, but the first attempt to fix failed, so it needs some more work. For now as a workaround put back the original display and reset the trip computer while it is installed. I'll try to find a solution to fix that also.
Offline Hokum
  • Country: ua
Hi
Would you tell me, can I connect a car security system via this interface?
Information about open doors, control the door lock, etc.
I have 206, and I had to make mini board to connect to the door lock to control it.
Offline morcibacsi
  • Country: hu
It should work. There is a guy who created some kind of alarm system for a 206 with my TSS463 library. He worked on the slow VAN body bus which is 62.5 kbit/sec.
Offline henrioliver
  • Country: br
Hi @morcibacsi, how is the project for parking? ask me a question, the ESP32 is only for programming or does it need to be on the board for the display to work? Thank you
Offline morcibacsi
  • Country: hu
Hey, unfortunately I did not have the time to install the sensors on my car yet, so the function is not that well tested. I only tested it a little on my test bench and it seemed like it worked. The code is there on github, and if you enable it from the config.h file then it should work. The ESP32 is installed inside the car, behind the dashboard (connected to the ISO connectors).
Offline henrioliver
  • Country: br
now to work only the new onboard computer of the 307, is it necessary the ESP32 is on the board all the time to convert networks? thanks
