i have the OBD PP2000 which is a good help for decoding frames tests
Thanks, for sharing some experience with VAN bus hacking
Probably it will be good idea to buy something like this
amazon: PP2000 OBD II Scanner Diagnostic Tool For Citroen Peugeot but unsure if PP2000 software is included and what about any licence keys needed to renew from year to year?
Another thing is that I've found VAN 9004/9005 between BSI and instrument cluster connected with PP40 center display with ambient temperature, simply date and some warnign messages.
Unsure, how this OBD II tools could have access to this VAN from this connector located in BSI?
Does it capable catch those messages I'm interested in between BSI and instrument cluster?
Schematics which I've found but from UK version so Passenger fuse box (BSI) is on opposite side to my version-steearing wheel on left side
http://postimg.org/image/6p7t3fu33/Anyway, I'm soldering today this prototype CAN/VAN connected with 16MHz MPU and will try catch some frames but directly in MPU.
I've successfully tuned MPU to 64MHz PLL divided by 4 in hardware gives 16MHz system clock, but I haven't got crystal for the moment-idea was similar to V-USB try to make calibrations based on watched VAN/CAN bus datalink activity, but it is easy redesign this PCB to add 16MHz clocks on two left pins which now are used in this prototype to test also light sensor based on reverse baised cheap LED diode, which I might need for another project, so for the moment those pins will be used for testing such bidirectional light interface with limited speed, but fully galvanic insulation between car electric system and data receiving visualisation circuit.
I will try detect VAN/CAN frames by adjusting software and reflashing MPU code rather than do it on PC based on logged data.
I have no idea if it works, but we'll see what we get when we connect this thing to showed above audio connector
Mean time trying to get more familar with PP2000 software YT videos to see how it works and determine if it could be helpfull to hack communication between BSI and instrument cluster showed in linked again UK version of Peugeot 206 electric circuit which makes sense, when made teardown some time ago as shown in previous posts, so I feell comfortable to connect MCP2551 there to this audio connector when designed PCB with MPU and MCP2551 will be ready, I hope today, tomorow...
