Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Looking for connector ideas to carry USB + 24V (3A)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Looking for connector ideas to carry USB + 24V (3A) (Read 844 times)
guscrown
Regular Contributor
on:
August 23, 2018, 03:49:05 pm »
Hey guys,
I'm looking for a possible replacement for this FCI connector:
https://www.digikey.com/products/en?keywords=74355-1042
which is part of the Powered USB family.
So far it's been pretty good, but it has become more difficult to source, and lead times are pretty long, and considering that only FCI makes it, we are pretty much stuck.
I'm looking for an alternative that I could use to replace it. This is for a printer in a POS system. Printer is a USB device, and it requires 24V with a max current consumption when printing of 3A.
Any ideas?
Logged
Gribo
Frequent Contributor
Country:
Re: Looking for connector ideas to carry USB + 24V (3A)
Reply #1 on:
August 23, 2018, 04:54:50 pm »
In a pinch, D-sub can be used for USB 1.1. Alternately, you can abuse an RJ45 or a 10 position RJ50.
Logged
I am available for freelance work.
guscrown
Regular Contributor
Reply #2 on:
August 23, 2018, 05:38:45 pm »
The device is a USB 2.0 unfortunately, however the 10 position RJ50 doesn't sound that bad. What would be the best way to distribute the cores?
24V: 3 cores
Gnd: 3 cores
D+/D-: - 2 cores
VBUS : 1 core
USB_GND: 1 core
Logged
Gribo
Country:
Reply #3 on:
August 23, 2018, 08:29:00 pm »
D+/D- should be close to each other (using a twisted pair). Do you really need a separate USB_GND?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
