Author Topic: Driver circuit schematic for a 40kHz/60W ultrasonic transducer  (Read 3876 times)
Offline amp_architectTopic starter
  • Country: in
Hi all, I am making a DIY probe type ultrasonicator which I will be using for food samples. I will be attaching the transducer to a metal probe and I will need a driver circuit to excite it. I was thinking of either using a PWM signal (through a arduino) or a sine wave (sine wave generator circuits). I figured out using a square wave would be counterintuitive for my purpose as it would generate harmonics. Is there any preexisting circuit/schematic that would match my purpose? Thank You!
Offline MariuszD
Re: Driver circuit schematic for a 40kHz/60W ultrasonic transducer
« Reply #1 on: August 17, 2025, 07:26:21 am »
Applying a square wave to a transducer is a bad idea, but a square wave is easy to generate. In practical implementations, a square wave is applied to an LC circuit consisting of a transformer and a transducer. The LC circuit must be tuned to the transducer's resonance. There's only a sine wave on the transducer.
Example of an ultrasonic cleaner diagram.
https://www.edn.com/teardown-reverse-engineering-an-ultrasonic-cleaner/
For amateur experiments, it's better to build a low-voltage push-pull circuit.
« Last Edit: August 17, 2025, 04:06:32 pm by MariuszD »
