Usually in three phase applications I see varistors connected between phase to phase, or between phase to ground. In the picture below from a power supply reference design, the common node of the varistors is not connected anywhere. I would expect it to be ground, but they intentionally left the common point of the varistors floating. How are varistors protecting in this case?
