Author Topic: Vertical Amplification Output from DSO Scopes (specifically the Rigol 1052)  (Read 3893 times)
Offline sacherjjTopic starter
I've been looking around for this and haven't been able to find it.  From what I've been reading, there is a pass/fail connection on the back of the Rigol with a BNC connector.  The only functionality I'm seeing is testing if a waveform meets a predefined test.
Is there any way of doing a "Vertical Amplification" output on the back of DSOs and the 1052 in specific?  Back when I was doing electronics more and had access to a nice analog scope, I would route the vert amp output from the back of the scope to the back input on the Signal Tracer.  This was great to be listening to what you were probing at times.
Offline Simon
  • Global Moderator
    • Simon's Electronics
the rear output on the rigol scope is just an optocoupler output, it will trigger if the waveform goes out of set limits of a sample waveform stored on the scope. You can also set your own waveforms i think but don't know how
Offline tecman
Given that most of the world within is digital, it is unlikely to have a "vertical output" like you would see in and analog device.
paul
This is what I expected.  I was hoping, but not expecting, that there was some type of buffered output of the input signal, as it is very hard to sample along with the probe without affecting the signal.
Wish the answer was different, but thanks for the confirmation.
alm
  • Guest
You could probably use an old analog scope as a buffer amplifier in front of both your DSO and signal tracer. It would require you to change vertical attenuator settings on the analog scope, though.
Some of the higher-end DSO's have a signal out, one example is the Tek TDS5000 series, but these kind of features are often skimped on with the low-end, bottom of the barrel instruments like the Rigol, and even the low-end instruments from brands like Agilent, Lecroy and Tek. There's nothing preventing a digital scope from having an analog output, it's not like the signal is digitized before attenuation/amplification.
Offline tinhead
well, you can DIY.
Attached picture of Rigol input stage, blue lines are signals used by 500MSs/1GSs relays and trigger circuit, red arrows are
unused resistors in the resistor array. There you can get the vertical amp output. A good idea is to solder a small pcb
with buffer op-amp (can be diff opamp, but not necessarily. It need only act as buffer and line driver) and piece of cable out to
additional out bnc connector.
« Last Edit: April 23, 2011, 10:57:25 am by tinhead »
Offline tekfan
  • Country: si
I wouldn't try this unless the scope is meant to be used for frequencies below 1MHz or so. Even slight modification of the circuit can cause noticable abberations. A high speed opamp (>100MHz) can be a solution but even this can cause problems.
Even a good analog scope has a severely degraded analog output. If the scope bandwidth is 100MHz you can expect the analog out to be somewhere on the 30MHz range.
One can never have enough oscilloscopes.
Offline tinhead
nonsense, with proper designed circuit there is almost no influence,
the rest can be fixed via DSO internal self-calibration.
All you have to know is that BOTH channels need exact the same "load"
or the self-calibration will be unable to match the data (just because of how the ADCs are used).
i used OPA659 set to match 50Ohm impendanze (output), this worked without any issues.
