I buy ACS711's in reel quantities regularly. I actually love the non-contact, isolated nature of them, and they have such high instantaneous current ratings that I never have a problem.
When made a quick look at ACS711 datasheet, they says on top that:
ACS711 Hall Effect Linear Current Sensor with Overcurrent Fault Output for <100 V Isolation ApplicationsNotice this <100V isolation applications, which is not acceptable even in my DIY spot welder project where 230VAC is used?
Really, those things are rated at such low solation applications?
Anyway, when searched for them at Digikey they specified its response to current as:
~ 45mV/A 31A
~110mV/A 13A
which doesn't look great eg. for 31A.
I will check tomorow response to current of my custom SS495A based Hall effect sensor shown a few links above with a few turns of thick copper wire with at least 230VAC insulation, but It should be much more than 100mA/A i guess, but limited by +/-2.5V @ 5Vcc, so I should be able detect currents close to 25A.
Which is more interesting, when we calculate at 30A resistance losses in ACS711 eg. this quite nice 8-SOIC with 1.2m Ohm, we get close to 1W loss in this small part, while in the case of my custom Hall effect sensor with thick 2.5mm2 wires, I expect much less losses.
This is tradeoff in those Hall effect sensors, between Vcc used, than at 5Vcc, it is clear that while we have only +/-2.5V available for linear current sensing when we want sense let say up to 10A, than we have 2.5V/10A~250mV/A, and lowest currents capable to sense sometimes limited by Vcc precision and accuracy, but we should remember that Earth magnetic field is in the range of 0.5 Gauss, which means we can hit the point where this small Hall effect sense current which we could sense with high precision power supply will interfere with Earth magnetic field and it will not allow to go for such high precision Hall effect current sensing.
Hopefully, for high current applications I'm interested in even 250mV/A is fine since in my custom Hall effect current sensor I can easy detect 1A overcurrent and even if i can estimate up to 10A only @ 5Vcc, sometimes it is fine, because I'm only interested in going above 1A, etc.
It depends on application, but 1.2m Ohm resistance of 8-SOIC ACS711 is not acceptable for me, while eg, at 100A there were... 12W eenrgy loss in this thing, which probably means it could quickly hit temperature of hot iron
