Author Topic: Very Low Cost Linear Position Sensor  (Read 13391 times)
Offline janoc
Re: Very Low Cost Linear Position Sensor
« Reply #25 on: May 21, 2018, 10:33:50 pm »
Yeah the laser rangefinder is a bit of an overkill for your needs also.
Another idea that may work is simply installing an IR diode and a phototransistor and measuring the intensity of the reflection. It is not super accurate and likely won't work for more than 50cm distance but for a drawer that is likely plenty enough already. I have seen this used for some novelty MIDI instruments in the past and it works reasonably OK.
« Last Edit: May 21, 2018, 10:40:06 pm by janoc »
